Go Back   Home > Forums > General Interest > Car Audio
Old 11th February 2011, 01:31 AM   #1
Default ORION XTR1200
does anybody know of a respectable place i could purchase some 2SD1047 & 2SB817.
Old 11th February 2011, 12:12 PM   #2
B&D Enterprises - Electronic Components Distributor
I have one of these in the shop and the regulator resistors (circled in photo) have been replaced. Can you tell me what they're supposed to be?
Old 11th February 2011, 05:16 PM   #3
180 ohm 5%
brown grey brown gold
File Type: jpg regulator resistors 180 ohm XTR1200.jpg (148.4 KB, 55 views)
Old 11th February 2011, 05:23 PM   #4
Thanks.
Old 19th February 2011, 02:30 PM   #5
when i got this amp everything was shorted. i replaced all the power supply fets and 1 emmiter follower pair. then i replaced all of the outputs, drivers and predrivers. the amp is producing clean audio but my predrivers are getting hot. they were all originally CEN-U57/CEN-U07. it seems like somewhere i saw that perry said it was okay to replace those parts with 2N6488/2N6491 (just reroute the 3rd leg). so that's what i did for all of the drivers and predrivers. in the tutorial i see he has used the MPSW42/MPSW92, should i use those as the predrivers or did i make a mistake using the 2N6488/91's all together?
Old 19th February 2011, 04:14 PM   #6
If the original transistors weren't defective, you should use them. The W42s and W92s were in a 2150 or a 2250 (don't remember). I've never tried them in this amp. The 88s and 91s should be OK but if the originals weren't defective, there's no need to use the subs. Sometimes, transistors run hot normally. It doesn't necessarily indicate that there is a problem.
Is the board in your amp easily damaged when soldering/desoldering? To date, the old Lanzar Opti-Drive amps had the worst boards but this amp seems to be worse. The amp appears that it may have had some exposure to water. I don't know if that's contributing to the weakness of the pads.
Old 19th February 2011, 04:21 PM   #7
i just took my old predrivers and am now using them as the drivers and i have the mpsw42/92 as my predriver. i just did this in 1 channel so i could compair, and it is definately running cooler (even with the smaller package). is there anything wrong with that? if not i will do the same to the other channel moniter it and then try it with aload.
Old 19th February 2011, 04:30 PM   #8
If they are not running too hot and you test it thoroughly, there's nothing wrong with using them.
Orion GS300 Clipped Car Audio 10 11th December 2008 10:30 AM
Orion #5 Clipped Car Audio 1 21st November 2008 04:34 AM
Need help with Orion HCCA425 reppans Car Audio 4 30th November 2007 12:22 PM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
The Orion is available diypole Multi-Way 0 2nd October 2002 03:05 PM
Page generated in 0.09081 seconds (86.31% PHP - 13.69% MySQL) with 11 queries
