Go Back   Home > Forums > General Interest > Car Audio
Old 10th February 2011, 07:41 AM   #1
impsick is offline impsick  United States
impsick's Avatar
Default Eclipse ZA1200 dead, help
Hey fellas got a Eclipse ZA1200 mono car amp that has failed on a friend of mine. I Opened it up and there is no sign of any burning or blown parts. Looks clean like new. Hooked it up to some power and this is what happens....
If i hit it with 12v it immediately engages the protection and draws no current.
If i ease up the voltage from say 5v and up it draws current but once i get to 12 volts it shuts off. At about 8v its drawing .5a.
Another thing there is a ticking sound coming from the pcb. I cant figure out what making the noise.
Any ideas? thanks
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 10th February 2011, 07:49 AM   #2
Is there any DC on the speaker output (measured directly across the speaker terminals) as you increase the voltage?
Can you post a photo of the inside of the amp?
Old 11th February 2011, 04:56 AM   #3
impsick's Avatar
yes there is some dc on the output. with 6v-10v depending on source. here are some pics but like i said there is nothing visible. Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Old 11th February 2011, 12:05 PM   #4
I was hoping that it was similar to something that I was familiar with but it's not.
Did you measure the DC voltage directly across the speaker terminals?
Have you tried to get the service manual from eclipse?
Old 17th February 2011, 09:17 AM   #5
impsick's Avatar
yes i measured the dc off the speaker terminals. No Load. With a load each terminal measures +/-200mv to ground. With out a load, amp draws .5a from my bench supply at 9vdc. With a load it draws 200ma and the ticking goes away. If that makes any sense.
if you look at image 3 i circled two diodes just before the output that were hot to touch. the other two diodes on the (-) output were not hot. idk hopefully someone has had similar experience that can point me in the right direction. thanks
Old 17th February 2011, 12:45 PM   #6
Dead Dead Laser Pickups - why not replacing the Diode only? Salar Digital Source 9 24th January 2010 01:44 PM
CD8053 Eclipse corradolvr Car Audio 4 8th September 2007 06:14 PM
Eclipse TD712z JRKO Full Range 44 19th September 2005 09:19 PM
Eclipse Brian Donaldson The Lounge 5 28th October 2004 08:32 PM
Eclipse? Larr_e_boy Multi-Way 0 7th June 2001 02:41 PM
Page generated in 0.08395 seconds (75.30% PHP - 24.70% MySQL) with 10 queries
