Amp is stuck in protection mode.
here is my U14, Does this look correct? (UC3526N) 1 = 4.88 2 = 3.70 3 = 4.76 4 = 4.64 5 = 4.80 6 = 0.00 7 = 0.00 8 = 4.41 9 = 3.62 10 = 1.92 11 = 0.00 12 = 4.58 13 = 6.51 14 = 15.29 15 = 0.00 16 = 6.52 17 = 15.26 18 = 4.95 |
#2 |
U21 is the most likely suspect. Post the DC voltage on all of the pins of U21.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
U21
----- 1= -8.17 2= 7.61 3= -8.73 4= -9.52 5= 4.94 6= -3.41 7= 8.20 8= 9.51 |
#4 |
Replace it.
#5 |
Thanks perry, will do.
Might i ask what exactly this IC controls or does? Thanks |
#6 |
It's used to shut the amp down when there is over-current and is also responsible for the mute delay. These ICs commonly fail in a way that causes the inverting input (pin 6) to leak to the negative power supply for the IC. When pin 6 is negative, you know that the IC has failed.
| Combined DC protection and tweeter protection? | CopperTop | Solid State | 10 | 13th January 2011 07:52 AM |
| where i can get the toroids for rockford 1001bd and 1501bd | stoke | Car Audio | 6 | 21st November 2010 01:00 PM |
| Help with rockford 1001bd | stoke | Car Audio | 17 | 9th September 2010 02:52 AM |
| RF 1001bd turn-on pop | valterdaw | Car Audio | 9 | 2nd October 2007 08:01 PM |
| Amp stuck on | audiobahnkid592 | Car Audio | 1 | 8th July 2007 11:31 PM |
| Page generated in 0.07803 seconds (72.93% PHP - 27.07% MySQL) with 10 queries |
