Got another one of theese amps in for repair. Wondering if i can cut the mesha board here and repalce it with a small section of mesha board out of a scrap amp?
Since i dont have a mesha board long enough for this amp. |
#2 |
Technically, you could use kapton tape and heat sink grease or Sil Pads if you were willing to make buss bars. If you are going through the trouble to cut a MESHA board, you may as well just de-solder the bad transistor(s).
#3 |
Still have problem with this amp after replacing the fets and drivers i get no gate signal and amp draws excessive current. I unsoldered the twisted wires and still draws excessive current.
With the power supply fets removed I have the following voltages on the SG3526N 1:11.34 2:6.32 3:10.67 4:11.11 5:11.37 6:6.82 7:6.62 8:6.82 9:10.86 10:8.58 11:6.82 12:11.37 13:6.82 14:13.20 15:6.82 16:6.82 17:13.21 18:11.40 |
#4 |
You could use the MEHSA insulator out of another identical amp but you have to cut it in a way that won't deform it. If you try using tin snips or something similar, the insulator will not remain perfectly flat,
Pin 15 should be at 0v.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
PIN 15 connects to pin3 of U7 (LM6361N) Theese are the voltages i have
1:2.29 2:3.23 3:6.83 4:2.28 5:0 6:3.28 7:4.28 8:2.28 Defective? |
#6 |
I'm sorry, I should have said it should be connected to ground. Pin 15 is the ground pin for the 3526.
#7 |
I tracked it back to U7 then back up to the drivers for the power supply fets But no connection to ground terminal
#8 |
OK heres what i have on the LM339
1:6.84 2:6.84 3:13.21 4:6.90 5:8.41 6:9.05 7:11.40 8:6.38 9:6.38 10:11.40 12:6.82 13:6.84 14:6.84 |
#9 |
What is the DC voltage on these two points?
#10 |
The point next to the rail cap i have 0 volts. The point next to the tantalum cap i have 4.92 volts
| Rockford Fosgate BD1000 | mike49504 | Car Audio | 1 | 9th January 2011 11:37 AM |
| Rockford Fosgate | dtisme | Car Audio | 1 | 5th October 2010 11:39 PM |
| Rockford Fosgate BD500 | mike49504 | Car Audio | 9 | 18th July 2010 07:43 AM |
| Rockford Fosgate 100x2 | fongman | Car Audio | 45 | 8th November 2009 04:59 AM |
| rockford fosgate transistors | mike49504 | Car Audio | 2 | 20th January 2007 03:26 AM |
| Page generated in 0.10020 seconds (79.90% PHP - 20.10% MySQL) with 11 queries |
