Go Back   Home > Forums > General Interest > Car Audio
Old 2nd February 2011, 03:40 PM   #1
Default Orion HCCA 225 Digital Reference with Low Output
I picked up a barely working Orion HCCA 225 Digital Reference on a trade and it has extremely low output.
Thus far I've checked the SMP60N06-18s in the Power supply section as well as the 2n6491s and the 2n6488s and nothing appears to be shorted or open. Rail voltage is where I think it should be at 22.5 volts.
I guess I am off to troubleshoot the audio section next but I did have a couple of questions. What are the chances that there are bad capacitors blocking the audio signal from passing through the amp? Also, if I decide to replace the SMP60N06-18s, would the IRF3205 be a viable substitute?
Old 2nd February 2011, 06:22 PM   #2
Remove the two muting transistors (2N5639 near the audio op-amps). Does that help?
Old 4th February 2011, 03:31 AM   #3
Removing the muting transistors worked like a charm.
What do I need to do to solve the problem?
Old 4th February 2011, 03:34 AM   #4
What is the DC voltage on the third pad for the muting transistors?
Old 4th February 2011, 03:57 AM   #5
-10.83 and -10.89
Also, by third, I am assuming you mean the squares since these are reversed as mentioned in your repair tutorial.
Edit: After testing the JFETS that I pulled, it appears that they are both shot.
Old 4th February 2011, 04:23 AM   #6
It appears that the FETs are defective. -11 volts should have them switched completely off (allowing audio to pass). On a gen 2 225 I have here, the muting is essentially completely defeated at -3v.
Old 4th February 2011, 04:24 AM   #7
Thank you for the help kind sir!
Old 4th February 2011, 04:32 AM   #8
If you order replacements, order extras.
A side note, it's good to see that you took time to find that orion page and read it.
Orion 225 Hcca digital reference Bunn Swap Meet 0 30th January 2009 12:25 PM
Orion 225-HCCA av8rdav Car Audio 7 7th September 2008 05:50 AM
Orion HCCA 225 vs 225R ECM Car Audio 0 29th June 2005 11:04 PM
Schematics for Orion HCCA 225 D.R. tobias_svensk Car Audio 1 3rd April 2005 07:46 PM
Page generated in 0.08089 seconds (74.59% PHP - 25.41% MySQL) with 10 queries
