Go Back   Home > Forums > General Interest > Car Audio
Old 30th January 2011, 02:43 AM   #1
Default Alpine MRP-M1000
I got this amp in for repair and it had 32 defective outs and a D600K .
I then noticed that ZD4901 is defective also. Its a HZK12A2L diode.
Wondering if anyone know if theres a diode i can put in that location for right now to troubleshoot the amp somemore before i order parts.
So wondering if theres a good diode i can sub for right now to troubleshoot somemore.
Old 30th January 2011, 03:28 AM   #2
It's a 12v. 1/2w Zener. A standard 1/2w (or greater) Zener could be used for testing.
Old 30th January 2011, 03:58 AM   #3
Would a 1n4148 or 1n4150 work?
Old 30th January 2011, 04:12 AM   #4
Those are switching diodes, not Zener diodes. A 1N5242 or a 1N4742 would work.
Old 30th January 2011, 04:23 AM   #5
Ok put a 1n4742a in the amp and it draws excessive current then it goes dead then draws excessive current.
When the amp does this all outputs heat up and D9902 gets hot .
Any ideas?
Old 30th January 2011, 04:54 AM   #6
The driver ICs may have failed also.
Old 30th January 2011, 09:51 PM   #7
Does anyone know where i can get the driver ic's for this amp?
Allied electronics show 2 different 1's a 15 lead and a 16 lead .
I have the 16 lead 1 but they show no stock on that 1.
The parts number is IR2010S
Old 30th January 2011, 09:57 PM   #8
INTERNATIONAL RECTIFIER|IR2010SPBF|IC, MOSFET DRIVER, HIGH/LOW SIDE | Newark.com
The 15 pin description is likely a typo. Call or email them to confirm if you want to buy from allied.
alpine mrp-m1000 mike49504 Car Audio 45 16th October 2011 10:03 PM
alpine mrp-f250 bdgf2004 Car Audio 12 2nd September 2011 04:26 AM
No output from MRP-M1000 BlackCivicHatch Car Audio 24 2nd January 2011 03:10 AM
Alpine MRP-F200 mike49504 Car Audio 3 27th May 2010 07:29 AM
Alpine MRP-M1000 argonrepublic Car Audio 2 11th August 2009 02:28 PM
Page generated in 0.08233 seconds (76.05% PHP - 23.95% MySQL) with 10 queries
