Rockford MEHSA needed
Old 27th January 2011, 11:31 PM   #1
Jat40 is offline Jat40  United States
Jat40's Avatar
Default Rockford MEHSA needed
Been working to repair this T4000.1, see thread below, for a while now. The amp runs but has an output whine that I just can't locate the cause. The only difference in this amp and others that I have repaired, is it is missing the MEHSA boards in the power supply. I got the amp and these were missing. As a temp fix, I am using insulators.
So, my next option is to see if anyone has a compliment of MEHSA boards for a T4000.1 power supply that they would be willing to part with?
Rockford Fosgate T4000 - Output Whine
JT
Old 29th January 2011, 12:12 PM   #2
Jat40's Avatar
As reference, these are the MEHSA boards
JT
Old 25th February 2011, 12:27 AM   #3
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
I also need a MEHSA board just like the one you have pictured for 4 output transistors in a Punch 500. Were you able to source any or have any to spare?
Old 25th February 2011, 02:49 AM   #4
Perry Babin is offline Perry Babin  United States
Dr Zeus, did you see the MEHSA conversion page on the DVD?
Old 25th February 2011, 12:50 PM   #5
Dr Zeus's Avatar
I did, and I realize what I can do to convert this MEHSA for my 4 output transistors... However, this MEHSA board has a single surface mount transistor right on it and would need to be retro-replaced as well.
Can I convert it to say a TO-92 style transistor? What transistor could be a suitable replacement?
Old 25th February 2011, 06:01 PM   #6
You can use a TO-92 transistor. What is the exact model number of the amp.
Old 25th February 2011, 06:08 PM   #7
Dr Zeus's Avatar
Rockford Punch 5002. The one under the \puncht5002\ folder on the DVD is the one.
Is the surface mount transistor a 6B? BAT54A? Barrier Diode? Also it looks like from the picture theres a single surface resistor or diode as well.
Old 25th February 2011, 06:29 PM   #8
It's a transistor. An MPSA06 should be OK as a sub but you'll have to do some testing after setting the bias to confirm that the bias is not drifting.
You'd have to find the terminals of the 3-legged jumper that correspond to the base, collector and emitter of the SMD transistor so you'll know how to install the TO-92 transistor.
For this amp, I'd suggest using the Kapton MT film or Mica as insulators. Kapton tape may not work well enough.
Old 25th February 2011, 06:42 PM   #9
Dr Zeus's Avatar
Sounds good; thank you. If you think MPSA06 may not work, I should have more/other driver and pre-driver transistors in my toolbox.
Thanks!
Rockford MEHSA neededHide this!Advertise here!
If you hav ever worked with MEHSA insulators you'll get a kick out of this grandam88 Car Audio 4 23rd January 2011 02:46 PM
NOISE on audio system (Rockford 500a2, Sony xec1000, rockford PA2) stoke Car Audio 6 1st October 2010 10:21 PM
Help with rockford 1001bd stoke Car Audio 17 9th September 2010 02:52 AM
mehsa boards mike49504 Car Audio 9 6th October 2006 09:27 PM
rockford fosgate punch 200DSM - Help needed redimp Car Audio 7 20th September 2005 09:39 PM
Copyright ©1999-2017 diyAudio
