I REPLACED THE OUTPUTS IN THIS AMP ALONG WITH THE DRIVER IC'S AND A 330 OHM RESISTOR ON THE DRIVERBOARD.
WHEN TRYING TO POWER THE AMP UP THE RELAYS CLICK ON FOR A SEC THEN CLICK OFF AND AMP GOES INTO PROTETION. IF I REMOVE THE OUTPUT DRIVERBOARD AMP POWERS UP BUT THE GREEN LED DOESNT LIGHT WITH OR WITHOUT THE DRIVERBOARD. ANY IDEAS ON WHERE TO CHECK? |
#2 |
Which series sampson?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
XXV Sampson. On the output driverboard i found a bad cap (CL1) i replaced it . Anything else i should check?
#4 |
I'm not familiar with that amp. Photos of the driver board may help.
#5 |
Heres a pic of the driverboard
#6 |
On the output terminals of the output filter inductors, do you have DC on any of the inductors just before the relay clicks?
#7 |
I put the board back in after replacing that cap. Amp powerd up but after 3 to4 secs after the relay clicked on it sounded like something was shorting on the main board.
I also have Dc voltage on the outputs so i removed the board . I dont wanna blow the outputs. |
#8 |
Back to this amp again.
I replaced all outputs and let the amp sit for awhile now when i try power it up it draws excessive current. If i disable the output section amp powers up fine and idles around 5 amps. I checked all outputs in the amp they all tested fine I also have the output driverboard removed. Any thoughts on where to check or do i need to take all outputs back out of the amp and check for leakage? |
#9 |
Is there any DC on the output filter inductors when you power it up without the driver board?
| Hifonics Sampson | mike49504 | Car Audio | 3 | 4th December 2010 05:26 AM |
| Hifonics | dtisme | Car Audio | 3 | 7th August 2010 12:49 AM |
| hifonics 1606d | dtisme | Car Audio | 9 | 2nd August 2010 09:17 PM |
| Hifonics Problem | swordfish689 | Car Audio | 5 | 2nd April 2007 03:49 PM |
| Hifonics Cupid | Lasse- | Car Audio | 3 | 5th February 2004 10:28 PM |
| Page generated in 0.08045 seconds (78.79% PHP - 21.21% MySQL) with 11 queries |
