Go Back   Home > Forums > General Interest > Car Audio
Old 25th January 2011, 02:13 AM   #1
Default I have a Kenwood Kac-1023 amp and need HELP...
I have a Kac-1023 amp that I currently have on my two 10in L7 kickers and love it had it many years and just yesterday it started blowing fuses on amp. Notice it happened when I hit a large pot hole. The amp has four sets of 20 amp fuses the two closer to upper corner blow as soon as I replace them... I did disconnect the speaker wires but not the rca jacks as someone here recommended to do so ...Gonna try to fix this amp hope it's a easy and not a costly fix...
What my sound system includes is a CAP Second audio battery box with two L7's....
Old 25th January 2011, 02:50 AM   #2
If the fuse blows with no remote voltage applied and the problem began when you hit a bump, you should begin by removing the cover an looking for evidence of damage. I've seen broken legs on the rectifiers in these amps. If a gate leg on an FET has broken, it could cause this sort of problem. It's also possible that there's a tiny strand of wire that's fallen across two points.
Old 25th January 2011, 10:26 AM   #3
Thanks for the responce all the help is greatly appreciated. Another question I have is. I am using the amp for bass only which I'm using the LOWPASS FILTER setting on bridges/mono position where should my frequency responce should be set at. Also where should my input sensitivity level be at?
Joe
Old 25th January 2011, 05:07 PM   #4
The gain setting depends on too many variables. A good starting point for the low pass crossover is 90Hz. You'll have to adjust it to suit your listening preferences.
Old 25th January 2011, 05:48 PM   #5
Sorry for newbie questions but the lower the Hz the deeper the bass?
Old 25th January 2011, 06:27 PM   #6
Confirmed! Still blowes fuses with RCA & Speakers detached..Gonna take to a shop after work fingers crossed!
Joe
Old 28th January 2011, 03:22 PM   #7
Update.. Local shop told me it was 6 transistors wondering what in the world caused this to happen..
Old 28th January 2011, 04:01 PM   #8
Sounds like a blown power supply issue, and this could be caused by many different reasons. Old age, being over-driven, bad 12 volts and or grounding etc... too many to guess at without it being open on my bench and a inspection of your ride...
Old 28th January 2011, 10:48 PM   #9
Have two L7 10inch Kickers made up in a custom box..I have a extra audio battery in rear with a 2 Farad capacitor all connections are correct! My cables consist of 2 gauge + from main battery to rear with a 200amp fuse inline, And 4 gauge - to chassis. From rear battery to cap with 4 gauge wire to amp a simple set up. All was fine till I rode over some really BAD pot holes.
Joe
Old 29th January 2011, 12:19 AM   #10
perhaps the sudden shock of that event caused something to short out that normally would be fine and good. I have two KAC-1021's here and they are fairly solidly built inside, as with most OS kenwood gear, so unless i see the amp and the car I am still guessing at best here and so will most every body else. Just too many variables to hang the smoking gun on. Wish I could help more....
Kenwood KAC-1023 crossover/gain board, same as in other *23-series? gisewhcs Car Audio 9 25th January 2011 02:04 AM
Kenwood KAC-1023 sst12 Car Audio 0 19th September 2010 01:19 PM
Another KAC-1023 question sdoom Car Audio 1 19th August 2010 10:31 PM
Service manual for Kenwood KAC-1023 sdoom Car Audio 4 28th September 2009 12:27 AM
Kenwood KAC-X301T and KAC-X201T:Do they share the same board? spooney Car Audio 1 25th October 2007 01:08 AM
Page generated in 0.10360 seconds (80.45% PHP - 19.55% MySQL) with 10 queries
