Go Back   Home > Forums > General Interest > Car Audio
Old 22nd January 2011, 12:09 AM   #1
RiLoWa is offline RiLoWa  United States
RiLoWa's Avatar
Default Phoenix Gold XS2500 Help ID Components
This amp had prior work (pooly) done on it and I don't trust what I see. Can someone help identify/confirm them for me from the following pictures?
First pic is part of the right channel. Showing in front of Q215 somebody let the smoke out.
Second pic is part of the left channel. Showing behind Q115 from left to right, 47 Ohm resistor, 68 Ohm resistor, 6V Zener, and a 475 Ohm resistor.
Are those correct for both areas shown?
Third pic shows two resistors circled in red. The one on the left looks original but is burned. The one on the right looks replaced and is 150 Ohms. Is 150 Ohms correct for both spots?
Tools - 1. TPI Scope Plus 440 2. B&K 2125 20MHz Dual Trace 3. Sorensen DCR20-50B 4. B&K 4011 5MHz Function Generator 5. Weller WESD51
Old 22nd January 2011, 12:21 AM   #2
I'll be glad to look all those up for you but I have a appointment I have to run to tonight shortly. So if tomorrow is soon enough I'll get back with you on the info you want....C
Old 22nd January 2011, 12:22 AM   #3
RiLoWa's Avatar
That is plenty fast enough, thank you.
Old 22nd January 2011, 02:48 AM   #4
Once you remove the bad resistors in the right channel you will see the following board locations. Heres what goes in thoose locations
R239:47 ohm 1/8 watt resistor 5% tolorance
R238:68 ohm 1/8watt resistor 5% tolorance
D1:1N5233B diode
R244:475 OHM 1/8 watt resistor 5% tolorance
Left channel resistors appear to be right in your pic.
R233: 150 ohm 1/8 watt resistor 5% tolorance
R218:51.2 ohm 1/8 watt resistor 5% tolorance.
R133: 150 ohm 1/8 watt resistor 5% tolorance
The resistors circled in red in your pic are locations R133,R233 yes they are both 150 ohm
Old 22nd January 2011, 03:21 AM   #5
RiLoWa's Avatar
Cool, thanks for the confirmation.
Old 22nd January 2011, 03:25 PM   #6
Mike is correct on all devices your asking about. Good luck...C
Old 22nd January 2011, 11:30 PM   #7
spooney is offline spooney  United States
These are great amps. Hope you get her straightened out. The first time I worked on one it was a painful but valuable lesson. Slightly more complex than your average repair of the output section in my case. Got it figured out with the help of 1moreamp and my buddy has been running her strong for over 2 years.
Old 23rd January 2011, 12:21 AM   #8
RiLoWa's Avatar
Awhile back I worked on an XS4600 that was actually an easy repair since nobody had been in it before and it wasn't rode so hard. A luxury I guess.
This amp on the other hand is a disaster. It wasn't worked on with skills to brag about, which is why I distrusted the areas above. I'll be keeping the defibrillator at the ready.
phoenix gold xs4600 poopydoopynoopy Car Audio 8 17th February 2011 02:38 PM
Phoenix Gold 2125...Help lele73golf Car Audio 0 23rd September 2010 05:09 PM
Help with Phoenix Gold EQ215x Messerschmitt Car Audio 3 27th April 2008 05:55 PM
Phoenix gold xs2500 blowing fuses spooney Car Audio 7 16th October 2007 02:37 AM
Phoenix Gold TI500.4 Bertje Car Audio 4 29th November 2006 08:18 PM
Page generated in 0.09559 seconds (72.55% PHP - 27.45% MySQL) with 11 queries
