Go Back   Home > Forums > General Interest > Car Audio
Old 21st January 2011, 01:15 PM   #1
m4ick is offline m4ick  United States
Default MA Audio HC4002, RSB1 and CSB1 values
These two components appear to have been clipped out leaving leads sticking out under the board.
The power supply has snubbers on the primary side but these two components appear to be secondary snubbers, tying one leg of each transformers secondary windings to ground. They are RSB1 and CSB2.
The top of the power supply waveform is blurred and I imagine this is the reason.
I will post pics when I find my bluetooth dongle but I'm hoping one of you has pics or the real thing on hand.
Thanks!
Old 21st January 2011, 01:36 PM   #2
It's right between the rail caps and one of the transformers.
Old 21st January 2011, 05:57 PM   #3
Anyone with an educated guess what values those might be? They are CSB1 and RSB1, I mistyped them the first time.
Old 21st January 2011, 06:47 PM   #4
I don't have anything on this amp. If they're connected between the secondary windings and the secondary ground, there should be 4 of them. Are all 4 missing?
Old 21st January 2011, 07:05 PM   #5
The secondary windings and center taps of both of the transformers are soldered together before they go to the rectifiers so they essentially act as one transformer.
One of the two sets of secondary windings is tied to CHASSIS ground via these two components, the other set of secondary windings goes to the rectifiers without anything like this. There is only one set of these two, and they were definitely in there, you can see where they scratched the board cutting them out.
Old 21st January 2011, 08:33 PM   #6
I had to stop using the term chassis ground because it was confusing. Do you mean the ground for the amp chassis or the vehicle chassis?
If you look at the end of these components that are connected to the transformer, is there a rail-rail swing (pre-rectifier) or is it the secondary center-tap?
Are these in series or in parallel?
Old 21st January 2011, 08:45 PM   #7
Vehicle chassis (negative battery).
Rail to rail swings, definitely not center tap.
Series.
Old 21st January 2011, 08:51 PM   #8
There doesn't seem to be any indication that they burned. Could it be that they made a mistake and removed these parts at the factory? It's not common to have the secondary windings connected in that way to the amp's primary ground.
Old 21st January 2011, 09:02 PM   #9
Not sure, it looks like someone had desoldered and resoldered some of the primary snubber components as well and they don't appear burned either. My friend bought this amp for $10. It had 1 shorted output, it powers up fine now but it looks like an amateur did a shoddy job clipping out components blindly.
The top of the power supply waveform on the primary side is somewhat blurry but not outrageously so. Would leaving these out make this amp terribly unstable if they were in there originally?
Old 21st January 2011, 09:32 PM   #10
If one end goes to the primary ground and the other end goes to a secondary output winding, I don't think they should be installed. I'm assuming that the secondary center tap (non-bridging speaker terminals) is not connected to the primary ground.
MA AUDIO HK401SX mike49504 Car Audio 9 22nd November 2010 04:22 AM
MA AUDIO HC4002 mike49504 Car Audio 3 13th October 2010 04:26 PM
MA Audio AMP mike49504 Car Audio 4 23rd September 2010 08:45 PM
MA Audio Tom7227 Class D 0 31st August 2010 08:18 PM
MA Audio 802sx help judtoff Car Audio 2 12th November 2007 02:25 PM
Page generated in 0.11695 seconds (83.77% PHP - 16.23% MySQL) with 11 queries
