This amp powers but does not play. The test speaker presents the pretty standard Class-D low amplitude white-noise but nothing more.
The amp is in great shape and has never been opened. There are no burned components inside to speak of. The rail voltage is +-62vDC referencing general ground. The opAmps on the pre-driver board 9Left of photo) all measure +-12vDC on the power pins referencing amp general ground. After a few minutes, vertical driver boards get warm but touchable. I tried swiveling the gain pots and controls to no avail. The quiet sound of the sea out of the test speaker does not change. I'm about to take it fully appart, but past experience with this type of thing tells me it might be simpler than something hidden under the PCB. Resistence on RCA shields is 40k just about everything on the board including speaker terminal outs and amp ground. Im not sure where secondary center tap would be on this amp. Why wont this amp make sound?
#2 |
Exploring more with the RS Miniamp, I find that some of the opAmps have sound on the input and output pins, and some do not.
#3 |
WOW this is a big amp. Possibly one of the most costly I've repaired as well. Kicker MSRPs this bad boy for ~$1,400. Its Class D Monoblock, 2500x1 at 2 ohms. WOOW.
This amp has 20x IRF3205 transistors 12x IRF640, and 20x IRF9640. I need to get this thing fixed lol! I pulled the board out of the sync. Darn; no signs of trace damage... Last edited by Dr Zeus; 20th January 2011 at 10:20 PM. |
#4 |
Do you have clean audio on the output pin of the preamp board?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
I'm not exactly sure which one of these pins transmits the audio to the main PCB. The 9 pins are labled as pictured. Starting fro mthe bottom which appears to be Pin1 - REMBAS - I measure the following DC voltages referencing amp general ground:
Pre-Amp board pins: Pin 1: 10.51 labeled REMBAS Pin 2: 0.005 labeled GNDS Pin 3: -11.75 labeled -12v Pin 4: 12.00 labeled +12v Pin 5: 0.005 labeled GNDP Pin 6: 13.36 labeled +BATT Pin 7: 13.41 labeled REMOTE Pin 8: -19.84 labeled MUTE Pin 9: -10.61 labeled SUB_IN ![]()
#6 |
Q101 and Q102 are measuring 50 ohms from legs 1-2. They are M09 transistors, or PMBFJ309.
Datasheet: http://www.nxp.com/documents/data_sh...08_309_310.pdf Pin 1 is source, Pin 2 is drain. Are these bad perhaps or are they muting circuitry? |
#7 | |
Here is where I'm thinking secondary center tap is on this amp. its ~2ohms to general ground. ![]()
#8 |
That's normal for those transistors.
The secondary CT is the same as for most amps. Do any of the op-amps on the preamp board have significant DC on their output pins?
#9 |
U107 has -10vDC on all pins except but pin 8, which has +12
U106 has +-12vDC on the power pins, and -10vDC on pins 6 and 7. The other opAmps have ~0vDC on all output pins
#10 |
U107 appears to be defective. I'm assuming that it's an op-amp.
| kicker 450.2 | timwebb | Car Audio | 5 | 26th May 2010 05:59 AM |
| Kicker 600.1 | mike49504 | Car Audio | 3 | 25th March 2009 04:10 PM |
| Kicker SX650.1 help | shagone | Car Audio | 12 | 19th March 2008 07:35 AM |
| Kicker Vs. Memphis | irokpierce | Car Audio | 1 | 23rd August 2005 03:12 PM |
| adire? kicker? anybody? | jadenlinkletter | Car Audio | 5 | 22nd April 2005 01:37 PM |
| Page generated in 0.11006 seconds (82.49% PHP - 17.51% MySQL) with 10 queries |
