Kicker ZX2500.1
Kicker ZX2500.1
Old 22nd January 2011, 06:32 AM   #11
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
I thought so too. Its a JRC 2068. Maybe I'll order a dozen and give U107 and U106 new ones.
Old 22nd January 2011, 10:17 PM   #12
Dr Zeus's Avatar
I removed U107 and powered the amp up. The pads under U107 are measuring as follows:
Pin 1: 0
Pin 2: 0
Pin 3: -12
Pin 4: -12
Pin 5: 0
Pin 6: 0
Pin 7: 0
Pin 8: 12
U106 is still in place. Its measuring as follows:
Pin 1: 0
Pin 2: 0
Pin 3: 0
Pin 4: -12
Pin 5: 0
Pin 6: -12
Pin 7: -12
Pin 8: +12
Would -12 on Pin 6 of U106 make it defective?
Old 22nd January 2011, 10:26 PM   #13
Perry Babin is offline Perry Babin  United States
When op-amps are used for audio, they virtually always work to make the inverting input have the same voltage as the non-inverting input. Since pin 5 (the non-inverting input) is at 0v, the op-amp should drive the output to bring the inverting input (pin 6) to 0v. Since it isn't doing that, it's likely defective. I'm assuming that nothing (external to U106) is driving the output to -12v.
Old 22nd January 2011, 10:42 PM   #14
Dr Zeus's Avatar
I'd say we nailed it.
Since its tough without a schematic to really see what was driving the inverted input pin 6 to -12v, I used process of elimination.
Removing U106 revealed the following pad voltages measured with the DVM
U107:
Pin 1: ~0
Pin 2: ~0
Pin 3: ~0
Pin 4: -12
Pin 5: ~0
Pin 6: 0.325*
Pin 7: 0.325*
Pin 8: 12
*Pin 6&7 are tied together on the PCB. Do you think 0.325vDC on here is too much?
U106
Pin 1: ~0
Pin 2: ~0
Pin 3: ~0
Pin 4: -12
Pin 5: ~0
Pin 6: ~0
Pin 7: ~0
Pin 8: +12
Old 22nd January 2011, 10:48 PM   #15
Whatever U106 is driving is likely producing the 0.325v.
The output of U106 is driving the inverting input of U106. In this configuration, the op-amp is simply a buffer (output = input to non-inverting input).
Old 22nd January 2011, 10:54 PM   #16
Dr Zeus's Avatar
Very well. What else is cool is that I'm actually seeing audio now on what looks like all of the input and output pads where the JRC2068 opAmps on U106 and U107 were. Before I was seeing mostly nothing or +-12vDC.
Looks like last night's order of opAmps may provide some positive outcome.
Thanks!
Old 22nd January 2011, 11:13 PM   #17
Dr Zeus's Avatar
I'm assuming I need U106 and U107 for something, otherwise the amp is able to produce a sine wave at the speaker terminal outputs. I wonder if those opAmps are for the RCA outputs - supposedly the other amp in line with this one really blew up from what the owner told me.
Old 22nd January 2011, 11:33 PM   #18
If the transformer shorted in the other amp or a speaker wire shorted to ground (assuming cheap amps with floating secondary), it could have damaged the op-amps feeding the outputs on this amp.
Does the output RCA produce audio?
Old 23rd January 2011, 02:37 PM   #19
Dr Zeus's Avatar
The output RCAs produce audio as expected. I think these opAmps have something to do with the LP crossover as that control does not seem to be affecting the audio output correctly. This amp's crossover cannot be disabled, and even setting it to ~50hz allows the amp to play frequencies way above at equal volumes. The crossover is just not working right now. I'll post up when I receive and put new parts in.
Old 27th January 2011, 10:41 PM   #20
Dr Zeus's Avatar
This amp is FIXED! Two 2068 JRC opAmps and she's good to go. Cost was only about $0.60 to fix, but I ordered a few extra for the next amp
Kicker ZX2500.1Hide this!Advertise here!
kicker 450.2 timwebb Car Audio 5 26th May 2010 06:59 AM
Kicker 600.1 mike49504 Car Audio 3 25th March 2009 05:10 PM
Kicker SX650.1 help shagone Car Audio 12 19th March 2008 08:35 AM
Kicker Vs. Memphis irokpierce Car Audio 1 23rd August 2005 04:12 PM
adire? kicker? anybody? jadenlinkletter Car Audio 5 22nd April 2005 02:37 PM
