Soundstream XXX6500 - Page 14 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 29th January 2011, 05:57 AM   #131
Orderd a new IC and new drivers for the amp once they come in ill see what happens
Old 4th February 2011, 08:04 AM   #132
Put the new ic in the amp. Now it just draws excessive current And sounds like it wants to blow up theres a loud clicking noise comming from somewhere on the board but its not the relays.
Old 4th February 2011, 11:04 PM   #133
Sometimes the inductors and transformers will make a clicking noise if high current is pulsed through them. Are any of the outputs heating up?
Old 7th February 2011, 06:41 PM   #134
Do i need the outputs in this amp to test voltages on pins 8.9,14 ? Im gonna go through this entire amp today.
Old 7th February 2011, 07:06 PM   #135
Ok with black probe on secondary center tap of the little transformer .
PIN8:0
PIN9:14.0
PIN14:18.6
RESISTOR
R18
1side:18.5
Other side 27.8
It appears that that circuit is working now Just wanna confirm this?
Old 8th February 2011, 03:31 AM   #136
That looks OK to me.
Old 11th June 2011, 03:07 PM   #137
Great thread, very informative. Perry, I have an xxx6500 that isn't feeling well, and I'm at a loss as to where to look to next. When I got the unit it had quite a few output fets blown as well as bad solder joints on the power supply transistors. I relaced all of the output fets with Fairchild equivelants and re-soldered all of the bad joints I found throughout the board. Now when I power it up, one of the bank of 7 fets immediately blows with a couple of them flaming up. I've gone through every diode, transistor, and fet that I can find on the board and they all check good. I did CRT repair for years but am fairly new to amplifier repair (trying to fix this for a friend) so I'm looking for a good starting point. I've read quite a few articles on theory of operation of class D amps, but have yet to find any schematics for this beast. Any ponters would be appreciated.
Old 11th June 2011, 04:39 PM   #138
Working with a large (50-100 watt) 2 ohm resistor in the B+ line and having the transistors clamped to the heatsink will virtually eliminate the possibility of blowing the power supply FETs.
Email me.
babin_perry@yahoo.com
Soundstream Goliath xxx6500 problem chemhaz Car Audio 0 24th May 2010 12:43 PM
Soundstream MC245 . . . Again poopydoopynoopy Car Audio 10 12th May 2010 02:37 AM
Soundstream shaolinfox30 Car Audio 1 24th July 2007 09:03 AM
soundstream 6.0 ben04srt Car Audio 10 11th March 2007 04:56 AM
Soundstream? thylantyr Pass Labs 6 10th November 2006 08:35 PM
Copyright 1999-2017 diyAudio
