Soundstream XXX6500
Soundstream XXX6500
Old 28th January 2011, 08:07 AM   #101
Perry Babin is offline Perry Babin  United States
What is the DC voltage on the cathodes of DD1 and DD2?
Old 28th January 2011, 08:17 AM   #102
mike49504 is offline mike49504  United States
DD1:20.24
DD2:20.24
Old 28th January 2011, 08:21 AM   #103
If you have 20v there, you should have voltage on pin 8. Didn't you confirm that pin 8 was connected to the cathodes of DP10 and DP11?
Old 28th January 2011, 08:29 AM   #104
PIN 8 connects to the anode side of DP10,11 (non striped side)
Old 28th January 2011, 08:30 AM   #105
When you checked DP10 and DP11, did you confirm that they read ~0.6 one way and open when the probes were reversed?
Old 28th January 2011, 08:37 AM   #106
DP10 DP11 are UF540's
OL
probes reversed
0.391
other 1
OL
Probes reversed
0.399
Old 28th January 2011, 08:47 AM   #107
Are all of the components in the circuit?
I was mistaken. The anodes of DP10 and DP11 would read 0 ohms to pin 8 of the driver board.
Let's take this step by step...
With the black probe on the secondary center tap of the small transformer do you have approximately 24v on the anode of DA1 and the collector of QA3?
Old 28th January 2011, 08:57 AM   #108
With the black meter probe on secondary center tap of the small transformer i have the following.
DA1 anode side:32.74 volts
QA3 collector:32.72 volts.
Old 28th January 2011, 08:59 AM   #109
With the black probe on the same point...
Voltage on each end of R18?
Voltage on each end of R19?
Old 28th January 2011, 09:04 AM   #110
R19 or RA19?
Soundstream XXX6500Hide this!Advertise here!
Soundstream Goliath xxx6500 problem chemhaz Car Audio 0 24th May 2010 12:43 PM
Soundstream MC245 . . . Again poopydoopynoopy Car Audio 10 12th May 2010 02:37 AM
Soundstream shaolinfox30 Car Audio 1 24th July 2007 09:03 AM
soundstream 6.0 ben04srt Car Audio 10 11th March 2007 04:56 AM
Soundstream? thylantyr Pass Labs 6 10th November 2006 08:35 PM
