I got this amp in for repair. The amp had 2 blown outputs so i removed them .
I still have problems with that channel since the new outputs got red hot . The other problem is the amp is producing both + - regulated and rail voltages but i have no output out of any of the channels. Any ideas on where to look? |
#2 |
Ok i checked again . ALL of the outputs get hot within secs
#3 |
did you check the output drivers?
All my battles have been won, But the war has just begun. |
#4 |
Biasing?
Gate resistors?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
i removed 4 bad outputs from this amp the other 8 are still in it.
All 8 get red hot within secs . The 4 i removed where bad the other outputs that are still in the amp tested fine. Do i need to turn all of the bias pots down in every channel? Also when i connect a sub to any channel i get fluttering on the outputs . I tested for DC on the outputs but theres none. |
#6 |
Turn all 4 channels down but before you do, measure the bias voltage across the test points to see what the factory bias is.
Do you get fluttering with no RCAs plugged in?
#7 |
Well i figured out the fluttering problem.
Wheres the test points for the bias on this amp? |
#8 |
Near the white source resistors.
What was the fluttering caused by?
#9 |
When i plugged in the RCA's i didnt notice it at first but i had the rca's plugged into my sine wave generator not the test deck
#10 |
Ok are you talking the diodes for the test point or is there anyway you can put arrows in the pic thats in the previous post?
| Jl audio 500/1 powers on with low audio out help needed | ivkata | Car Audio | 29 | 19th August 2011 12:21 AM |
| JL Audio 10w6v2 or Infinity Kappa 100.3se? Audison SRX4 or Jl 300/4? | DcMaN | Subwoofers | 1 | 17th September 2010 10:28 AM |
| Repair JL e6450 Amp | krazchikin | Car Audio | 3 | 12th August 2009 07:40 PM |
| jl audio | nicandjade | Swap Meet | 0 | 2nd September 2006 10:35 AM |
| Page generated in 0.11344 seconds (80.77% PHP - 19.23% MySQL) with 11 queries |
