i just got this amp and this part has blown.looks to be part of the current sensing in the amp.all i can read is hmr?
#2 |
If I'm not mistaken, the P-channel FETs use a 0.04 ohm resistor and the N-channel FETs use a 0.02 ohm resistor. There should be enough readable ones to confirm this.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
i looked up the part number but didnt get any where.
#4 |
This should get you closer. You'll have to measure them to get the correct size.
current sense resistor 0.04
#5 |
ok i got the amp to function but it has a ground issue every time i touch a gain nob or a rca jack it goes into protection.
#6 |
Assuming that there is no significant DC on the RCA jacks or across the speaker terminals... Does the amp produce clean audio when you connect a signal source and speakers?
Is the body of the pot loose (does the body wiggle more than the other pots when you touch it)? Have you checked the RCA shield ground?
#7 |
ok there is 4vdc on the rca. 0vdc on the speaker terminals, all the pots are firm and in place. but does not produce audio.
#8 |
Do you have both positive and negative regulated voltage on the op-amp power supply pins?
#9 |
all TL072 op amps have 23.v and the 4559 have 11.5v
#10 |
Do all of them have negative voltage as well?
| Page generated in 0.07543 seconds (85.44% PHP - 14.56% MySQL) with 10 queries |
