Go Back   Home > Forums > General Interest > Car Audio
Old 16th January 2011, 01:23 AM   #1
Default fosgate series 1 2600x
in one channel the bottom half of the output cuts in and out quickly and randomly. this is with no load. i set my meter to diode check and compaired readings in both channels on several components and so far they all seem identical. i think i had this problem before in another fosgate amp and perry said it was probably something in the protection circuit.
Old 16th January 2011, 02:44 AM   #2
In this amp, I'd suspect broken legs on the outputs.
Old 16th January 2011, 03:40 AM   #3
i've pressed and wiggled on the outputs with no result, should i remove them?
i noticed that on the wire terminals the B+ is located next to the output of the defective channel. i mentioned this because the plastic divider between the terminals is broken making it very easy for the B+ to come into contact with the speaker output.
Old 16th January 2011, 02:33 PM   #4
Generally, if the legs are broken, moving the body of the transistor would make it distort. Are you losing negative rail voltage? Check at the leg of the output transistor.
Old 16th January 2011, 03:21 PM   #5
i have full rail voltage on both the outputs in the defective channel. but i did notice that on pin #1 of Q427 i am getting negitive rail voltage, it will kind of flash up and down between a few volts but stays well in the negitive. i compaired the the readings of the outputs while still in the circuit and all are identical with my meter on diode check (now i have a fluke 112). should i pull Q427 to see if it is defective?
Old 16th January 2011, 04:35 PM   #6
The voltage on that pin should remain about 3.5v above the negative rail. If it's jumping significantly higher and the amp isn't drawing excessive current or producing significant DC voltage on the speaker terminal, I'd suspect that the transistor is defective.
Old 16th January 2011, 09:19 PM   #7
i checked the fet (Q427) out of the circuit and it tested okay. so to be sure i installed a new IRF540 and i does the same thing. since i had the fet out i check the pad for pin #1 and looks a little different but it is still jumpy.
Old 16th January 2011, 10:03 PM   #8
The voltage on the gate pad won't be reliable for troubleshooting with the output out of the circuit. You should reinstall the output.
Does Q410 appear to have overheated?
Do you have any freeze mist or canned air?
Old 17th January 2011, 01:22 AM   #9
i removed and checked Q410 and it seemed okay. so i went ahead and tried a new MMBTA56 and now the amp seems to work fine. so far it's been playing for about 15 minutes.
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 24 10th May 2009 03:24 AM
fosgate 1998 series power 500.2 amp blowing fuse jbrooksgametech Car Audio 13 26th November 2008 06:21 PM
fosgate series 1 260 amp ben04srt Car Audio 3 16th August 2008 03:19 AM
Yamaha CA-series / CT-series parts DragonMaster Parts 9 19th January 2007 07:48 PM
Quality of Hammond 300 series power transformers compared to 200 series? G Tubes / Valves 8 21st September 2003 02:27 PM
Page generated in 0.10527 seconds (76.98% PHP - 23.02% MySQL) with 11 queries
