Go Back   Home > Forums > General Interest > Car Audio
Old 15th January 2011, 04:01 AM   #1
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
Default Rockford Punch 4040DSM
Working on this little guy for a shop, I first noticed the 4x BUZ11s were toast so I replaced them with IRF3205s, but not before fixing a voltage problem at the gate. I found a shorted surface mount transistor (3B / BC856B) from base to collector so I replaced it with an MMBT3906 as that is all I had which was close to the 3B description wise.
Gate voltage now rides at 6.1vDC whereas before it was hitting ~8vDC. I didnt replace them, but all 4 gate resistors are sitting at 100ohms +- 2%.
CR7, a 39v Zener, was shorted so I clipped it off the PCB but have not yet replaced. CR6 was OK.
I didnt clamp down the transistors yet, but already notice that powering the amp off my 5A supply causes the fets to get warm after about 20 seconds.
The amp has +- 20vDC rail voltage.
With inputting sin wave through RCAs - with the scope I was able to see a good sin wave output at all four speaker terminals. I have yet to hook up a test speaker as I really dont want to fry the new 3205s.
Old 15th January 2011, 04:30 AM   #2
Dr Zeus's Avatar
I removed the rectifiers and the power fets still get hot pretty quick.
On the scope, the fets are outputting a clean +25v square wave, however the rise side of the square wave has a straight line pointing up to 45v.
Old 15th January 2011, 01:14 PM   #3
Did you change the gate resistors to 47 ohms?
Old 15th January 2011, 02:11 PM   #4
Dr Zeus's Avatar
No. I guess thats it then? Wow I feel like a dummy.
Old 16th January 2011, 02:57 AM   #5
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
So if I did not change the gate resistors in punch 500 and I installed the new IRF3205s, would I have problems with transistors heating up?
Feel the PUNCH
Old 16th January 2011, 02:38 PM   #6
Yes.
Old 17th January 2011, 01:30 PM   #7
Dr Zeus's Avatar
Replacing the 100ohm resistors with 47 ohm units solved the heat problem with the 3205s. Now when the amp powers up the channel nearest the endplate with the power terminals seems to be striking in-and-out of over-current protection. I dont have an amp meter but I can tell my bench power supply strains for 2 seconds on, 2 off.
I measured the DC voltage across the defective channel's emitter resistor and it keeps flipping from 0.050v to 0.001v every ~2 seconds. After about 15 seconds of the amp doing this I felt heat coming from transistors on the driver board. The output transistors check OK by the dvm.
What is the trick to testing little transistors like this on verticle driver boards? Its sometimes hard to touch all the transistor legs when they are so close together.
Old 17th January 2011, 02:40 PM   #8
Bias current?
Old 17th January 2011, 03:00 PM   #9
Dr Zeus's Avatar
Well, the bias pots are all full counter-clockwise on all channels. I usually do that so an amp is not easily fried while working with it. I think one of the surface mount transistors on the driver board has a problem; one or some get too hot to touch.
Old 17th January 2011, 03:12 PM   #10
Please post a photo of the inside of the amp?
Rockford Fosgate Punch 30 warpedhifi Car Audio 2 9th November 2010 04:28 PM
rockford punch 500.2 scampo77 Car Audio 26 12th April 2010 02:35 PM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Rockford Punch 501S defect JoergST Car Audio 6 24th December 2006 10:55 AM
Rockford Punch 250x2 gti311 Car Audio 6 14th October 2005 07:26 PM
Page generated in 0.10085 seconds (77.61% PHP - 22.39% MySQL) with 10 queries
