I've been having a mad scientist idea that I wanted to try, and I really want to try it even more after eating lunch with a friend last week.
How hard would it be to create a circuit that provides phantom power and reverse the channel inversion used to bridge old school Orion amplifiers through the DIN plug? I ask because I have one of these negative feedback controllers: ![]() ![]() And I've been wondering if I could adapt it to work with something other than the Orion 280GX that it was designed for. Also, I believe this is the wiring spec for the MIDI/DIN plug: ![]() For some reason, I am thinking that 15v phantom power will be easier to achieve than reversing the channel inversion. I'm handy with a soldering iron, but circuit design is something I lack.
#2 |
Unless this circuit modifies/distorts the signal, it's not likely to make a difference. All it can do is compensate for the effect that the speaker wire has on the signal. Unless you're using very small wire or have to run it a very long distance, this isn't likely to be beneficial.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
That "circuit" is an electronic suspension system.. ie a servo. It contain an xo, bridging circuit, comparator circuit, loudspeaker modeling unit and signal modification circuit.
The bridge circuit in the negative feedback unit (NFU) can be defeated for an amp that has a built in bridging switch. The "issue" is to make a stand alone phantom power supply to provide > +/- 12 VDC to the NFU. As you can see in your picture that voltage is regulated down to +/- 8 VDC.
Troy Thinking positive doesn't make things better, it makes you a better person. |
| +/-15V from +48V Phantom | Pilbromatic | Parts | 4 | 9th August 2009 05:46 AM |
| Circuit Sanity Check: +15V, -15V, +9V Power Supply | miallen | Power Supplies | 4 | 18th July 2009 07:18 PM |
| +/-15V power to a TI PGA2310. 15V regulators sufficient or do I need adjustable?? | nick_g_evans | Parts | 2 | 16th July 2008 11:50 AM |
| Power Supply For Pre/ Head Phone & Phantom... (PCB) | Ayne | Power Supplies | 0 | 28th April 2007 04:10 PM |
| Using 15V laptop power supply on t-amp | aussiebuddha | Class D | 9 | 20th September 2006 12:44 PM |
| Page generated in 0.07699 seconds (70.25% PHP - 29.75% MySQL) with 10 queries |
