Punch 500a2 distorted channel
Old 21st March 2011, 05:36 PM   #61
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Originally Posted by seankane View Post
Or....Is this the one you have????
Looks alittle different from mine still. The blue capacitors are almost in the center near the speaker fuses. I believe i have the 86/87 model?? It's missing parts like the bass and treble pots, power supply fets and a small transistor, speaker fuses, and the left side is shorted (checked with meter) and the list goes on.... haha
& it has two transformers forgot to add that to description. And i'm waiting on my 200a4 to arrive....
Feel the PUNCH
Old 21st March 2011, 06:04 PM   #62
I just turn the fets over and apply a small film of flux then heat them up with your iron till the flux starts to bubble then hold the solder to the fet until it melts, remove the iron briefly hold the legs with another tool or something then run your iron over the back of the fet and spread the solder. Be careful not to get them to hot and dont get excessive solder on them. It does not take much because keep in mind there is solder on the mesha pad as well. A butane torch works the best for heating the mesha board and installing the fets. The off color dull grey IRF 3205's tin much easier than the shiny chrome looking ones, the solder almost spreads itself on the dull colored ones. Hope this helps.
Quick question? What does Rockford mean when they say they use "N type V-FETs"? I was reading the owners manual for a series 1 amplifier. So they all N channels for the output? So like only IRF540s are being used?
Feel the PUNCH
Old 21st March 2011, 10:02 PM   #63
seankane is offline seankane  United States
seankane's Avatar
More than likely they could all be IRF540's the V-FET is just their construction and an abbreviation for mosfet. I posted a pic so you can see.
Punch 500a2 distorted channelHide this!Advertise here!
ONKYO AVR401: distorted sound in one channel TB Solid State 4 3rd December 2010 06:55 PM
ppi pc2150 distorted right channel 67elcamino Car Audio 16 29th August 2009 07:46 AM
Distorted left channel - Marantz 2385 jblmar Solid State 2 27th March 2009 06:04 PM
Distorted left channel Proton 520 Amp allank Solid State 1 13th September 2006 02:41 PM
Help!! Right Channel Freq distorted. TPC Tubes / Valves 3 16th January 2003 03:27 PM
