Go Back   Home > Forums > General Interest > Car Audio
Old 18th January 2011, 06:10 PM   #41
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
I have a problem with the left channel on this amp. Q123 hets to hot and the so does Q113 side that i removed the bad outputs, source resistors. I was checking other components and i couldn't find anything else or i'm not checking right? I don't want to install the new outputs yet because Q123 & Q113.
Feel the PUNCH
Old 18th January 2011, 06:22 PM   #42
What's the DC voltage measured 'directly across' R174 and R175?
Old 18th January 2011, 06:51 PM   #43
R175: 012.3mV
R174: 012.7mV
And Q113 has 24.03 dc on base & collector. Is that normal???? And it gets really hot!
EDIT: R175 & R174 kept rising.
Feel the PUNCH
Old 18th January 2011, 07:22 PM   #44
Do you have any solder bridges between the pads for the outputs?
Confirm with your meter set to ohms that no two adjacent pads read near 0 ohms. Check all of the output pads for this channel.
Old 18th January 2011, 08:18 PM   #45
Can I ask where am I getting 24 volts from on the driver transistor? Explains why things were getting hot. I really want to fix this but I am unsure where the source is on this problem. What would be an approximate 'good' reading for the SMT parts when measuring continuity?
I am starting to hate this amplifier.....! -.-
Feel the PUNCH
Old 18th January 2011, 08:28 PM   #46
Did you check for the bridges between the pads with your meter?
Things are unpredictable (voltage-wise) when components are missing from the feedback loop (this includes the outputs). If you want to repair this, you need to eliminate one problem at a time.
If you're checking components in the circuit, you can compare one channel to the other (meter on resistance, probe placement identical for each component being checked, no power applied to the amp).
Old 18th January 2011, 09:04 PM   #47
I did and I didn't get anything near 0 from gate, drain, source i did get high resistance readings thought from source to drain, drain to source. I also replaced a 2A transistor with another working 2A transistor.
What if the bias pot is turned up?? Could this cause problems?
Feel the PUNCH
Old 18th January 2011, 09:22 PM   #48
It should be set fully counter-clockwise until you get the outputs reinstalled and clamped down.
I'd suggest that you install the outputs, clamp them down tightly to the heatsink, insert a 10 amp ATC/ATO fuse in the B+ line and power the amp up.
Does the fuse blow?
Do you have any significant DC across the speaker terminals of the repaired channel?
Old 18th January 2011, 09:33 PM   #49
Does the fuse blow?
I have new outputs, but i don't want to blow them and the old ones are shorted but I'll give it a try even if it shorts the new ones. And yea I have a 5 amp fuse inserted at all times during testing, trouble shooting. But if it blows the new outputs what does this mean???
Feel the PUNCH
Old 18th January 2011, 09:35 PM   #50
If you clamp them tightly to the heatsink and have a 5 amp fuse in the B+ line, there is virtually no way to damage them.
ONKYO AVR401: distorted sound in one channel TB Solid State 4 3rd December 2010 05:55 PM
ppi pc2150 distorted right channel 67elcamino Car Audio 16 29th August 2009 06:46 AM
Distorted left channel - Marantz 2385 jblmar Solid State 2 27th March 2009 05:04 PM
Distorted left channel Proton 520 Amp allank Solid State 1 13th September 2006 01:41 PM
Help!! Right Channel Freq distorted. TPC Tubes / Valves 3 16th January 2003 02:27 PM
Copyright ©1999-2013 diyAudio
