Got another one of theese in for repair.
If i remove the IRF9640's and leave the 640's in The amp powers up. If i have both the 640's and 9640's in the amp it stays in protection mode. I tested all the Outputs and they all seem to test fine. ANY ideas? |
#2 |
Ok i tracked it down to the driver board.
Heres a list of Stuff im gonna need to rebuild it. Just wondering if you can confirm theese are correct before i place an order. Surface nount diodes and transistors. 2F=BC850B Location:Q10 A6=BAS16 Location 12,D6,D5,D118F=MMBZ5231B Location 8Z7=BZX84-C8V2 Location 7,D91P= MMBT2222A Location:Q9 |
#3 |
Ok disreguard my last post for now.
I pulled a KSP2907A From the board this is what i get. 1-2:OL 1-3:OL 2-3:30.79 Mohm probes reversed 1-2:34.25 1-3:OL 2-3:OL PN2222A 1-2:34.98 and meter climbs 1-3:OL 2-3:OL Probes Reversed 1-2:OL 1-3:OL 2-3:30.64 Do either of theese appear to be defective? |
#4 |
Those look OK. I'm assuming that 30.64 is Mohms, not ohms.
It's good to use both diode check and resistance when checking transistors. For example, the one that had the climbing readings would have given you a stable, more reliable reading on diode check.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
I listed some parts in post 2 wondering if you could confirm thoose are correct. If i pull all of the outputs amp will power up . If the outputs are in the amp the amp stays in protection but they all test fine.
#6 |
I have no experience with this particular amp so I can't give definitive answers.
Are all of these parts definitely defective? Did you look up the datasheets for each one and confirm that the markings were listed in the datasheet AND that the parts were identical (may need a dial caliper to measure accurately)? Even then, there's no guarantee. You'd need to find other parts in the amp with similar markings and confirm that the polarity of the transistor (NPN/PNP) is the same as those in the datasheets.
#7 |
Any ideas on what to check? I checked this and all seem to test good .
Only thing that worries me is the class D chip is bad. |
#8 |
On those, I've only seen the Zeners fail and one time one of the (missing) transistors failed.
#9 |
The zeners check fine (silver diodes on same side as the class D chip)
Heres what i have in diode check on the Transistors 2907 1-2:OL 1-3:Ol 2-3:0.613 Probes reversed 1-2:0.626 1-3:OL 2-3:OL 2222A 1-2:0.627 1-3:OL 2-3:OL probes Reversed 1-2:OL 1-3:Ol 2-3:0.616 They seem to test fine to me. Do i need to remove the smd Diodes and Transistors to test them? |
#10 |
Yes. Those seem OK.
I don't know how the transistors are being used so I don't know what's connected to them. You can really only check the see if they're shorted in the circuit. If you want to check them more thoroughly, lift two legs of each one and check them.
| American Bass VFL-500.1 | mike49504 | Car Audio | 5 | 7th January 2011 11:07 PM |
| American Bass CX-1200-D | mike49504 | Car Audio | 13 | 1st September 2010 03:59 AM |
| FS: Dayton sub 1200, Eminence sub, Seas mid-bass, HiVi, ATD, Axon | ccz | Swap Meet | 3 | 17th August 2010 08:54 PM |
| 3a Triphonic 1200 sub-bass schematics | MontrealMaggieB | Subwoofers | 1 | 1st July 2008 11:32 PM |
| Page generated in 0.10233 seconds (80.91% PHP - 19.09% MySQL) with 11 queries |
