Go Back   Home > Forums > General Interest > Car Audio
Old 11th January 2011, 08:22 PM   #1
Default Old School Test Equipment Resurrection - Warnings?
{Disclaimer} I would have posted this in a different forum but the intention is to eventually repair 2 RF Punch 150 HD's that I have laying around.
Back in my college days (early '90s), I was insanely into car audio and this included repairing amps and head units. At the time, I purchased some test equipment at auctions including a HP 200AB Audio Oscillator (tube based), HP 1200A Oscilloscope (also tube based, I think??), and a lab grade 12V 25A rack mount PS (linear).
Since these have been weathering the climate here in Virginia since 1995 in the garage, I am wondering what precautions/service steps I need to take before powering them up. They are now inside the house (after 15 years). Aside from some dust, they still appear fine externally. I figure I should give them several hours to acclimate to the temp inside my house which is about 40 degrees F higher than outside.
Beyond this, any suggestions or past experiences would be greatly appreciated.
Old 11th January 2011, 08:26 PM   #2
It's generally recommended that you bring the voltage up slowly. This allows any caps that have deteriorated to 'reform'.
If the humidity is high in the house and there is a chance of condensation forming on the interior parts of the equipment, you may want to wait 24 hours. The combination of dust and condensation can form conductive paths.
Old 11th January 2011, 08:35 PM   #3
Thanks, Perry. I will definitely wait 24 hours or longer as my house is quite humid. As far as bringing up the voltage slowly, I don't have a variac at present. I assume that is what you are referring to as it is test equipment (120 VAC input). If it is, can you recommend one? Otherwise, would a bulb tester setup work?
Old 11th January 2011, 08:45 PM   #4
Yes, a variac.
A 120v lamp in series would also help protect the equipment. If you have them, start with low wattage. 40w >> 100w would probably be good enough.
Old 12th January 2011, 03:27 PM   #5
After sleeping on it, I have decided that investing in a Variac would be a good idea. While I don't have much $ invested in my test equipment, replacing any one piece would likely be more than the cost of a variac. Can somebody recommend a particular model and vendor?
-Stu
Old 12th January 2011, 03:46 PM   #6
807tubenut's Avatar
Whom ever has the best warranty?
All my battles have been won, But the war has just begun.
Old 12th January 2011, 03:54 PM   #7
Thanks but [IMO] given the simplicity of a variac there is/should be little chance of something happening to it, right? Of course, that assumes it is used within the load range it is rated for.
-Stu
Old 12th January 2011, 04:48 PM   #8
sencore pr57
Ebay is where you'll find the best prices.
Old 12th January 2011, 05:15 PM   #9
Thanks again, Perry. I found this on CL:
General Radio Type W10MT3A 10 Amp Metered VARIAC, Great for Guitar Amp
Given my love of old [couldn't break it if you had to] equipment, it seems like a perfect fit. Actually, I am going to take a look at it in 45 mins or so and will likely pick it up. So yell quickly if I am making a huge mistake
-Stu
Old 12th January 2011, 05:19 PM   #10
I know nothing about that piece. I've had a pr57 for ~20 years and it's never failed to work properly. That's why I recommended it.
test equipment speedie Multi-Way 3 15th September 2009 05:33 PM
Test Equipment jwatts Swap Meet 1 18th November 2008 02:46 AM
Test equipment ID glen65 The Lounge 0 18th March 2008 09:41 PM
Old test equipment f.s. Cobra2 Swap Meet 0 4th March 2004 06:15 PM
What's this test equipment for?? hugobross Solid State 7 15th November 2002 03:54 PM
Page generated in 0.09401 seconds (80.70% PHP - 19.30% MySQL) with 10 queries
