DLM4000 class D driver board
Old 6th March 2012, 08:35 AM   #21
mariopinna is offline mariopinna
Good morning
Someone could send me pictures of the module without 1KW1CH integrated welded?
I need the links between the two chips
many thanks
Old 20th July 2016, 01:44 AM   #22
nonprof is offline nonprof
Hi Pergo, Did you able create your own modulator board? in replace of DLM4000? thanks! I badly need this for myself.
Old 17th January 2017, 03:04 AM   #23
Hello!
Anyone could give the pin out function of a DLM4000? I have a 6kwatts Firland mono amplifier but it produces distortion on the upper side of the sinewave.
Thank u.
Old 17th January 2017, 03:48 AM   #24
here at the attach picture of the output...I injected 100hz of sinewave. I replaced IRFP360 with a IRFP460(available). I'm thinking that DLM is defective.
Old 17th October 2017, 03:13 AM   #25
MRGARY is offline MRGARY
Good evening Pedro, if you have found a replacement module for the DLM4000A or know of where a replacement could be purchased, could you share it with me, my vested build is in need of one possibly two as a back up.
I have two Soundstream Tarantula xxx 10000D car audio amps and the module in one went bad.
DLM4000 class D driver boardHide this!Advertise here!
Sure Electronics New Tripath Board 4*100W class-D Amplifier Board 7788q Class D 354 17th March 2017 01:19 PM
1500W RMS Class D PCB - which Class D Driver Chip is it ? mosfetsound Class D 11 1st April 2011 11:17 AM
Massive Amplifier Class D Driver Board amc32 Car Audio 4 25th August 2009 11:22 PM
