This amp needs 4 x IRFZ44 in the power supply but also a complete channel worth of outputs. The outputs are A1673 and C4388 neither of which Mousre or Digikey has a listing for.
Can I use A1694 and C4467 as substitutes? I have those on order for a "600w" California Profile amp. Both the Kenwood and the California are "600w"... but the Profile is using 4 outputs and this kenwood is only using 2. Thanks! |
#2 |
The 4467 is rated much lower and wouldn't likely be reliable. If you want to use transistor in the case like the 4467, use the FJA4213 and FJA4313. You'll have to use insulators with them since they're not fully encapsulated.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Cool. Its about time I grab a few Insulators off Digikey.
Thanks! |
#4 |
You should order some of the Kapton from J&R electronix. It's a good insulator that can be cut to size.
| Kenwood P-T400 - line level output ? | jives11 | Analogue Source | 1 | 2nd October 2008 03:50 PM |
| Kenwood | thunder | Chip Amps | 3 | 20th February 2007 11:58 AM |
| Kenwood Equalizer | sandman | Solid State | 2 | 5th November 2006 09:27 PM |
| PLEASE! Kenwood help! | mjarve | Solid State | 1 | 23rd September 2004 04:04 AM |
| Enclosure for Kenwood Sub | sigops | Car Audio | 3 | 9th September 2004 05:44 AM |
| Page generated in 0.07861 seconds (67.28% PHP - 32.72% MySQL) with 10 queries |
