#31 |
I don't think that I've ever seen one of these amps with this problem so I wouldn't expect it to be a common problem.
A 10w resistor would work if you could find one to fit. The one you listed may work if the leads could be bent to fit the board spacing. I'd think that it would be very difficult to burn both resistors open since they're in series. It's probably not very common.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#32 |
My step-brother just had the same problem. Glad you guys did too as it looks like we have a solution.
#33 |
My 1000/ has no output. While taking it apart c515 came out. It looks like someone repaired this and r536 (diagonal of c515) 493-3526ND will work for c515? Which 5w5ohm did you go with? I just picked up a scope,ddm, and soldering station. Should i post a new thread when I'm ready?
#34 |
Yes. Start a new thread if you need help with your amp.
| JL AUDIO 1000/1 | mike49504 | Car Audio | 54 | 26th September 2011 07:43 PM |
| Jl audio 1000/1 | mike49504 | Car Audio | 1 | 22nd May 2010 08:21 PM |
| JL Audio 1000/1 - Parts query | Robbie_D | Car Audio | 6 | 13th September 2009 09:13 PM |
| jl audio 1000.1 amp prblem | ampjunkielikeme | Car Audio | 24 | 11th April 2009 11:21 AM |
| JL AUDIO 1000/1 (output problem) | Pioneer621 | Car Audio | 2 | 24th April 2007 06:17 AM |
| Page generated in 0.07578 seconds (68.83% PHP - 31.17% MySQL) with 11 queries |
