JL Audio 1000/1 - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 19th January 2011, 05:03 AM   #21
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
Is the ground for the signal generator connected to the power supply ground?
I've been meaning to make a ground connection for this signal generator. It does not appear to have one readily attachable.
Maybe I shoult try my iPod, but I'm affraid I might burn it out.
Old 19th January 2011, 05:10 AM   #22
Dr Zeus's Avatar
OK this amp is fixed. I guess I need to make a grounding point for my frequency generator, because my iPod is working just fine.
The fix for this amp was 3 caps near the outputs and 1 5w5ohm resistor. Plus a lot of cleaning supplies.
Also this amp has a load of dirty switches for which Ive found some contact cleaner and WD40 works very well to fix.
Old 3rd March 2011, 03:33 AM   #23
Rabbi is offline Rabbi  United States
Im in the same boat this guy was, i have the exact same blown parts.
Mouser wont have DME2W6P8K-F Cornell Dubilier Polyester Film Capacitors
in stock until the end of may.
Is this a suitable replacement? or is the temp rating to low.
http://www.mouser.com/ProductDetail/...BTqjT6QlI3M%3d
Old 3rd March 2011, 04:41 AM   #24
Mouser: 493-3526-ND ?
Old 3rd March 2011, 04:46 AM   #25
nobody has anything usable cheap and in stock?
i cant seem to find much
Old 3rd March 2011, 04:50 AM   #26
digikey has that 493-3526-ND in stock, should i go ahead and go with those ?
Old 3rd March 2011, 04:54 AM   #27
I've never used them but I think they should work. The amp only has 115v of rail so there no way it could exceed the AC or DC voltage ratings of the capacitors. You'll need to check the dimensions.
Old 3rd March 2011, 01:34 PM   #28
Dr Zeus's Avatar
Interesting another amp like this suffered the same fate. Could there be a design flaw or weakness in these or other parts? Or are users just overloading these amplifiers?
Old 3rd March 2011, 05:14 PM   #29
the only difference is that i blew both of the 5w5ohm resistor and you blew only one.
Strange indeed.
Maybe this is why jl came out with the V2 of the slash series amps?
Old 3rd March 2011, 06:37 PM   #30
would a 5ohm 10 watt wirewound resistor be usable?
I Cannot find a 5ohm 5 watt in the right package type.
this is the only thing i can find at digi, but i think i will have space issues.
http://search.digikey.com/scripts/Dk...e=CB5JB5R00-ND
JL AUDIO 1000/1 mike49504 Car Audio 55 11th September 2012 06:28 PM
Jl audio 1000/1 mike49504 Car Audio 1 22nd May 2010 09:21 PM
JL Audio 1000/1 - Parts query Robbie_D Car Audio 6 13th September 2009 10:13 PM
jl audio 1000.1 amp prblem ampjunkielikeme Car Audio 24 11th April 2009 12:21 PM
JL AUDIO 1000/1 (output problem) Pioneer621 Car Audio 2 24th April 2007 07:17 AM
Copyright 1999-2017 diyAudio
