This amp simply power cycles approximately every 6 seconds. The LED near the RCA labeled 'Shorted' flashes for ~3 seconds every ~6 seconds. When the LED is off, the amp in essence 'charges' itself and produces ~24vDC at the rails, but after ~3 seconds the shorted LED powers up and the rail voltage drops.
None of the power (1F27SP) or output (IRF540) transistors are shorted. I went ahead an pulled all eight IRF540s off the PCB and the power cycling still occurs. I was able to measure the TL494. These readings were taken in-between the power-cycling while the shorted LED is mainly not lit, unless I used a '~'. Pin 1: 2.300 Pin 2: 2.2 ~ 4.7 Pin 3: 3.450 Pin 4: 0.865 ~ 4.7 Pin 5: 1.513 Pin 6: 3.178 Pin 7: 0.016 Pin 8: 13.62 Pin 9: ~0 ~ 0.075 Pin 10: ~0 ~ 0.075 Pin 11: 13.62 Pin 12: 13.68 Pin 13: 4.97 Pin 14: 4.97 Pin 15: 4.97 Pin 16: ~0 ~ 0.075 |
#2 |
Can you post a photo of the inside of the amp?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
#4 |
Did anything change when you removed the outputs?
#5 | |
I let it power cycle for ~15 mnutes hoping it would make something get warm enough to start following the trail. The power supply fets get just slightly warm but nothing could get this adventure started. I'm thinking if I ground the TL494 pin 16 then it should stay on? This amp was almost tossed before I got so it could be an experiment. Last edited by Dr Zeus; 7th January 2011 at 11:59 AM. |
#6 |
Can you take some photos with your good camera (Kodak?) of the area around the LM339s? Email them to me at full resolution. Set the camera to the highest resolution possible.
babin_perry@yahoo.com
#7 |
I sent you an email with the image at 100% quality. Attached to this thread/post is a version at ~40% of the original's quality.
#8 |
It's going to take me a while to study this. I likely won't have time until tomorrow.
#9 |
Hey I'm back to working on this little MTX amp. I'm kind of lost with it to tell you the truth and had it aside for a little while.
#10 |
It would help quite a bit if I could read the numbers on the resistors. Try setting the camera to macro mode. You probably won't be able to capture the area all in one photo so take 3-4 photos to cover this area and email them to me.
| MTX Thunder 2300 | spooney | Car Audio | 59 | 11th August 2010 12:52 AM |
| MTX Thunder 81001 | megael9 | Car Audio | 13 | 30th May 2010 03:23 AM |
| MTX Thunder 81001 | mike49504 | Car Audio | 1 | 26th March 2010 09:19 AM |
| Mtx Thunder 2300 | vypr | Car Audio | 35 | 21st September 2006 07:35 PM |
| MTX Thunder 6152 Help | Ankst | Car Audio | 0 | 27th November 2005 05:21 AM |
| Page generated in 0.10241 seconds (79.70% PHP - 20.30% MySQL) with 11 queries |
