Go Back   Home > Forums > General Interest > Car Audio
Old 6th January 2011, 09:15 PM   #1
Default looking fot autotek mean machine 44 schematics
i have a old school autotek mean machine 44 amp with a blown resistor. i need a schematic for the amp as part was moved then lost(by a friend) all help is appreciated. thanks
Old 7th January 2011, 04:06 AM   #2
Can you post a photo of the resistor location?
Old 9th January 2011, 05:31 PM   #3
Click the image to open in full size.Click the image to open in full size.
here is a picture of the component location. If anybody has this amp plaease tell me what is at 1n4751 on the board, almost direct center of board nest to model number printed on board.
Old 9th January 2011, 05:33 PM   #4
That's a 1N4751 Zener diode.
Old 9th January 2011, 05:41 PM   #5
lol, i figured that number was merely a label for the location on the board, but then i saw the other components are all labeled also.
thanks for the quick reply, the guy that owns this amp has had this blow numerous times, but also he likes to run his amp @ 1 ohm with out flipping the switch over, would this cause the diode failure? of is there possibly an underlying problem?
Old 9th January 2011, 05:52 PM   #6
The load on the amp has nothing to do with this. If I'm not mistaken, this diode is the voltage regulator for the op-amps. In amps that tend to overheat this diode, I generally use two 1 watt 15v Zeners in series instead of one 1 watt 30v Zener.
Old 18th January 2011, 06:00 PM   #7
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
GrandAm88 - Do you still have this amp? I think I have one like it myself worth fixing - its an Autotek 44 by Zed. Can you shoot me a pic or two of the inside plus the component side of the driver board? I have not looked up much on it yet, but one channel seems to have a bad driver. Hope you still got it and got it working!
supertegrs@yahoo.com
Old 18th January 2011, 06:04 PM   #8
Dr Zeus's Avatar
You know what? nevermind I think... I just looked on amp-guts and seems there are two models of Autotek 44. Mine does not have the proprietary 'zed' inline components but does have a vertical driver board, and also mine uses hard-wiring instead of terminals.
Still, they are both Zed made amps right?
700va 44-0-44 Toroid, Bride of Zen BOZ and Zen PCB apoopoo999 Swap Meet 4 4th April 2010 02:01 PM
autotek 44 aka 7100bts problem with left channel eroc1313 Car Audio 15 18th March 2010 12:07 AM
Sowter transformer 8347 I/V stage fot TDA1543 elec-tron2 Digital Source 20 9th June 2007 07:46 PM
Fostex FE 167E flat enclosure fot HT promitheus Full Range 18 24th January 2007 01:37 AM
Page generated in 0.08585 seconds (75.79% PHP - 24.21% MySQL) with 10 queries
