JL AUDIO 1000/1
JL AUDIO 1000/1
Old 12th February 2011, 08:18 AM   #21
mike49504 is offline mike49504  United States
Ok nevermind i found Cap 826 shorted
Old 12th February 2011, 09:15 AM   #22
When i try to power the amp up the low ohm light is lit. Any ideas what to check now?
Old 12th February 2011, 09:21 AM   #23
Perry Babin is offline Perry Babin  United States
That generally indicates that the outputs have failed.
Old 12th February 2011, 09:44 AM   #24
All outputs test good.
Old 12th February 2011, 09:50 AM   #25
Remove the outputs. Desolder the pads to ensure that there are no bridges.
Does the low impedance LED still light up?
Old 12th February 2011, 10:10 AM   #26
Yes
Old 12th February 2011, 10:22 AM   #27
Have you checked the outputs out of the board (including checking for leakage)?
Are they the original outputs?
Old 12th February 2011, 10:26 AM   #28
Yes checked them out of the board several times And yes the are the orginal outouts (SSP45N20B).
If i take the driverboard out (U500) the light goes off.
Old 12th February 2011, 10:45 AM   #29
Ok maybe it doesnt I didnt have the Main board plugged in all the way amps low ohms light is still on
Old 12th February 2011, 11:27 AM   #30
Post the voltage on the pads for the driver board you removed.
JL AUDIO 1000/1Hide this!Advertise here!
Jl audio 1000/1 mike49504 Car Audio 1 22nd May 2010 08:21 PM
JL Audio 1000/1 - Parts query Robbie_D Car Audio 6 13th September 2009 09:13 PM
jl audio 1000.1 amp prblem ampjunkielikeme Car Audio 24 11th April 2009 11:21 AM
JL AUDIO 1000/1 (output problem) Pioneer621 Car Audio 2 24th April 2007 06:17 AM
JL audio 1000/1 amplifier problem jz23 Car Audio 1 6th April 2007 05:50 AM
