JL AUDIO 1000/1
JL AUDIO 1000/1
Old 13th January 2011, 01:54 PM   #11
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
Hey Mike,
Do you still have this amp? I'm looking for the values of these capacitors. i know one is a 10uF, and another is a 6.8uF.
The board designations are C514, C515, and C516.
Here is a pic of the amp/area I'm working on.
Thanks!
Old 13th January 2011, 02:07 PM   #12
Perry Babin is offline Perry Babin  United States
C515 is a 10uF. The other two are 6.8uF.
Old 13th January 2011, 02:08 PM   #13
m R g S r is offline m R g S r  United States
ouch! what was this amp powering?
Old 13th January 2011, 02:10 PM   #14
Dr Zeus's Avatar
Hey mRgSr. I have this amp posted i nthe other thread here:
JL Audio 1000/1
However... The owner said for ~years the amp was screwed to the back of a dual 12" subwoofer speaker box. I'm guessing rattles and distortion because the gains were at 100% when i got it.
Old 12th February 2011, 06:55 AM   #15
mike49504 is offline mike49504  United States
I have the diodes you said may work in this amp. SO D808,809,810 need to be replaced.
Which one goes where in this amp the 2 part numbers i have are:
UF4004
11DQ06
Old 12th February 2011, 06:59 AM   #16
SR106 = 11DQ06
Old 12th February 2011, 07:06 AM   #17
Ok thanks next question is on the led board (power light protections ect) there are 5 wires that solder to it THe yellow and orange wires are still attached.
the other locations are 1,2,3 and i have a red,brown and black wire do you know what order they go in?
Old 12th February 2011, 07:20 AM   #18
See attached.
When working on the JL amps, I tape the boards to the top of the capacitors (the LEDs drop between the caps). This keeps them out of the way and prevents them from shorting out to the main board when working on the amp. If you look closely, you can also see that Goop has been applied to the wires to prevent stressing the wires at the point where the insulation stops. This prevents them from breaking.
Old 12th February 2011, 07:34 AM   #19
Solderd all parts in . Now i have to track down why i have a directed short between power and ground trrminals
Old 12th February 2011, 08:10 AM   #20
Just took out the diodes and caps i just put in and took all of the power supply fets out. Its still showing a direct short between power and ground terminals (0.2 ohms).
Any idea what to check?
JL AUDIO 1000/1Hide this!Advertise here!
Jl audio 1000/1 mike49504 Car Audio 1 22nd May 2010 08:21 PM
JL Audio 1000/1 - Parts query Robbie_D Car Audio 6 13th September 2009 09:13 PM
jl audio 1000.1 amp prblem ampjunkielikeme Car Audio 24 11th April 2009 11:21 AM
JL AUDIO 1000/1 (output problem) Pioneer621 Car Audio 2 24th April 2007 06:17 AM
JL audio 1000/1 amplifier problem jz23 Car Audio 1 6th April 2007 05:50 AM
