This amp uses The IRFP064N as power supply fets. I cannot find them anywhere Everyone ive talked to says they have no stock.
Wondering if I could replace them with HUF75344G From future and be fine? |
#2 |
The 75344 should be a good sub. Newark has the 064s if you want the originals.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
I replaced the the drivers for the power supply fets in 1 supply .
I have the gate wave form on all power supply fets expect for 3 on each side so i have no gate wave form on 6 total fets in this amp. Is that normal or do i have a problem somewhere? |
#4 |
There's a problem. Check the signal on the bases of the driver transistors for the FETs with no gate signal. Confirm that the NPN driver's collector has 12v on it.
#5 |
found the problem Both diodes are shorted. The number is 1N5240B is there a good sub for theese?
#6 |
How were the diodes being used?
It's a 10v Zener diode. You need to use the same part or one with the same breakdown voltage.
| Trace Elliot AH 500-12 bass amplifier | elec972 | Instruments and Amps | 23 | 11th December 2011 03:51 PM |
| American Bass CX-1200-D | mike49504 | Car Audio | 13 | 1st September 2010 03:59 AM |
| Best bass horn 50 – 500 Hz | rick57 | Multi-Way | 37 | 6th March 2005 09:38 PM |
| FS: JL 500/1 ($500 CAD located in GVA) | Dynamix Lude | Swap Meet | 0 | 27th October 2004 03:21 AM |
| Page generated in 0.08304 seconds (71.42% PHP - 28.58% MySQL) with 10 queries |
