Go Back   Home > Forums > General Interest > Car Audio
Old 5th January 2011, 07:27 PM   #1
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
Default Hifonics Zeus Gen X
I got this amp from a show and it wont power up properly. Upon juicing it, the thermal trachind and Chameleon System Design lights shine up. Theres no rail voltage and none of the transistors are failing check while on the PCB. The TL494 has some wierdness about it, or maybe this is an old rev (Says Revision A on the pcb) or previous repair; or perhaps Im just not familiar enough with Zeus amps. On the other ZED amps I've worked with there was nothing like this mended with the TL494:
Its a 25v 47uF cap going from pin 11 to R5 (100 ohm).
Then on top of R5 theres a 1k resistor bridged between the 494's Pin 11 (AFTER the cap also attached to R5) and Pin 16.
TL494 Voltages
PIN 1: 0.095
PIN 2: 4.71
PIN 3: 4.74
PIN 4: 0.427
PIN 5: 1.412
PIN 6: 3.375
PIN 7: 0.000
PIN 8: 13.74
PIN 9: 0.000
PIN 10: 0.000
PIN 11: 13.74
PIN 12: 13.74
PIN 13: 4.90
PIN 14: 4.90
PIN 15: 4.90
PIN 16: 12.90
I remember from past experiance with ZED that the protection circuitry leaves pin 16 at ~12v when it senses a problem
Old 5th January 2011, 07:33 PM   #2
What IC are they using for the latch?
Old 5th January 2011, 07:36 PM   #3
Dr Zeus's Avatar
Its a 324D JRC M4124G and also has some funky circutry around it:
To the left of D5 is a 1/8w resistor bridging to R14, and then R14 is essentially bypassed with a piece of wire bridge.
Old 5th January 2011, 07:39 PM   #4
Post the voltage on that ICs pins.
Old 5th January 2011, 08:09 PM   #5
Dr Zeus's Avatar
324D Voltages
PIN 1: 11.97
PIN 2: 11.97
PIN 3: 11.97
PIN 4: 13.45
PIN 5: 0.075
PIN 6: 7.82
PIN 7: 0.075
PIN 8: -1.083
PIN 9: 12.27
PIN 10: 9.67
PIN 11: 0.000
PIN 12: 12.26
PIN 13: 7.82
PIN 14: 0.851
Old 6th January 2011, 02:26 AM   #6
It's strange that 1, 2 and 3 are exactly the same, do you read 0 ohms between them?
Pin 8 shouldn't be negative since the op-amp has no negative supply voltage. Is that an error? If not, what's connected to pin 8?
With pin 12 above pin 13, the output on pin 14 should be near the positive supply voltage. Either it's being dragged down by something or the op-amp is defective. What's connected to pin 14?
Old 6th January 2011, 02:45 AM   #7
Dr Zeus's Avatar
Between Pins 1 and 2 I read 4.7k ohms which I think is coming from NW4. Its a light blue network and is half pictured above and numbered CTSK9552 770 83 472 (The number is half pictured on the PCB above as well).
Between pins 1 and 3 measures 0 ohms and makes sense when you take into account that R14 has a bridge across it for some reason.
Between pins 2 and 3 measures 4.7 ohms and again is wired through the 770 83 472.
Pin 8 is indeed measuring negative. I should have starred it above. Pin 8 is connected through R12 and R13 (pictured). From the right side of R13 its tracing to the right side of D7 which is measuring OK. From the right side of R12 UNDER the PCB the trace is connected to Q7's leg1 which is a TIP41C. Q7 is measuring ok on the PCB. From the right side or R12 ON TOP of the PCB the trace is connected to C8 and then back to D7. I'm going to try pulling Q7 for testing shortly.
Pin 14 is connected to the 3rd pin from the left of PROT2/NW3 (Pictured).
Old 6th January 2011, 02:49 AM   #8
Dr Zeus's Avatar
Q7 is checking out ok off the board.
Old 6th January 2011, 02:54 AM   #9
What is the resistance from pin 14 to ground?
What, besides R12 or R13 is directly connected to pin 8?
Old 6th January 2011, 03:13 AM   #10
Dr Zeus's Avatar
I was slightly wrong about a trace I described from Pin 8. Everything is as described above, but this: From the right side or R12 ON TOP of the PCB the trace is connected to C8 and then traces back under the PCB at the hole pictured just to the right of D7.
This hole is leading to a few things; Pin 11 of the 324, C5, PROT2/NW3 right-most pin, then F2 tab in-between the transformers which is ground. I'm gonna pull C8 as its stuck measuring .8M ohms on the PCB.
Nothing else is connecting to Pin 8, and as best as I can see there are no traces connecting to it hiding under the 324.
Resistance from Pin 14 to ground is a slow rising 5.5k ohms. vVery slow. Every ~10 seconds rises .5k.
hifonics zeus vii mike49504 Car Audio 6 30th April 2012 05:31 PM
Hifonics GEN X Zeus mike49504 Car Audio 18 18th June 2011 06:31 PM
Hifonics Zeus VII warpedhifi Car Audio 8 27th September 2010 02:26 AM
Hifonics Gen X zeus mike49504 Car Audio 4 17th September 2010 04:31 AM
Hifonics zeus gen x mike49504 Car Audio 93 20th April 2010 11:20 PM
Page generated in 0.10131 seconds (78.11% PHP - 21.89% MySQL) with 10 queries
