Team Cactus 7kw - Page 9 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 5th January 2011, 12:12 PM   #81
Should i try replacing the caps?
Old 5th January 2011, 12:22 PM   #82
If you're 100% sure that the noise is coming from the caps and you can find replacement caps, try it.
Old 7th October 2012, 12:10 PM   #83
Viktor is offline Viktor  Yugoslavia
Send a message via ICQ to Viktor
Default Zennon 7KW
I can't find the service manual for the zennon oc cactus amplifier. I received for a repair one fully blown device which was once repaired and then blown again. I cleaned everything and replaced all transistors and driver IC's on amp driver board along with all resistors in gates and everything that measured wrong. Amplifier powers up and the sound is ok but after more than 50 W of output power it pops on speaker a few times and then shuts down. Since there is no distortion and the idle currents are low , there is no heating I suspect only the resistor values. I replaced the blown resistors with value that was on the old resistors but they were replaced in some other occasion. I need values for gate resistors for power supply output transistors mine are 1K which I found too big but maybe it is a part of the design. Other thing is that feedback resistor in the power supply controller is changed so I need also a value for R158 near 494 IC
Any help with these is very appreciated.
Viktor
how to 60hz to 50hz 7KW or more reliable but cheap!?? JinMTVT Everything Else 13 12th August 2009 03:23 AM
Lance Armstrong and Team Radio Shack pro cycling team Andersonix Everything Else 18 29th July 2009 04:39 PM
my graft cactus have succeeded! digi01 The Lounge 6 31st January 2005 03:32 PM
Copyright 1999-2017 diyAudio
