Team Cactus 7kw
Team Cactus 7kw
Old 5th January 2011, 10:48 AM   #71
mike49504 is offline mike49504  United States
Would an output inductor cause squeal on the outputs? I noticed when i recieved this amp in for repair that 1 of the output inductors was loose and had been removed from the board at one point when i get the squealing that same inductor also squeals . Or could it possibly be something else?
Old 5th January 2011, 11:15 AM   #72
Perry Babin is offline Perry Babin  United States
If the inductor is intermittently shorted, it may cause it to do strange things.
Is there anything that you can push on or move that makes it squeal.
Old 5th January 2011, 11:30 AM   #73
Only thing i can see is that inductor when i tap it it makes it worse and i can hear the inductor squealing and it sounds like its popping .
If i remove it from the board amp will still produce audio but the output still squeals is that because its removed or because there is another problem?
Old 5th January 2011, 11:33 AM   #74
Is it possible that there's an intermittent connection on that inductor and when the connection is open, the amp squeals? The vias may have been ripped from the amp when it was initially removed.
Old 5th January 2011, 11:40 AM   #75
I reflowed the solder on it didnt make it better But if i twist or pull on it it does make the squealing worse. Si if the vias was ripped from the amp when it was removed does that make the amp unrepairable?
Old 5th January 2011, 11:42 AM   #76
Does it always squeal when the inductor is out of the amp?
Old 5th January 2011, 11:51 AM   #77
The squealing is still present with it out of the amp but not as bad
Old 5th January 2011, 11:55 AM   #78
Can you see the squealing on the output (with the scope)?
Old 5th January 2011, 11:59 AM   #79
Yes . I also noticed there are 4 22uf 250v caps near the output inductors that are popping when i increase the input signal
Old 5th January 2011, 12:04 PM   #80
I had an amp with 'success' brand caps that were shorting intermittently and when it happened, they popped.
Team Cactus 7kwHide this!Advertise here!
how to 60hz to 50hz 7KW or more reliable but cheap!?? JinMTVT Everything Else 13 12th August 2009 03:23 AM
Lance Armstrong and Team Radio Shack pro cycling team Andersonix Everything Else 18 29th July 2009 04:39 PM
my graft cactus have succeeded! digi01 The Lounge 6 31st January 2005 03:32 PM
