#61 |
The 7815 appears to be installed backwards. If so, it's likely been damaged.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#62 |
Replaced it
Leg1:21.38 Leg3: 14.97 7805 Leg1:14.95 Leg3:5.02 |
#63 |
That looks better.
#64 |
So the problem is likely on the Output driver board? On the middle row of pins at 1 end the pin connects to an ic (U4) and at the other end the pin connects to a diode
#65 |
There was a problem with the regulator. There may be no other problem.
#66 |
Powerd up the amp and now it has 93 volts of dc on the outputs any ideas?
#67 |
Ok took care of the Dc on the outputs issue. Amp power up and plays audio but it has distorted audio and and hear a squeal through the test speaker. Any ideas?
#68 |
Ok found a problem In the power supply section Resistor R166 is very badly burnt anyone know the value of this?
#69 |
1K
It connects between the secondary ground and the heatsink (when the board is screwed down). There shouldn't be any voltage (AC or DC) on either end of it.
#70 |
Ok reinstalled A1381 and C1027 amp powers up and
produces audio but has squealing through test sub Any ideas? |
| how to 60hz to 50hz 7KW or more reliable but cheap!?? | JinMTVT | Everything Else | 13 | 12th August 2009 03:23 AM |
| Lance Armstrong and Team Radio Shack pro cycling team | Andersonix | Everything Else | 18 | 29th July 2009 04:39 PM |
| my graft cactus have succeeded! | digi01 | The Lounge | 6 | 31st January 2005 03:32 PM |
| Page generated in 0.10784 seconds (100.00% PHP - 0% MySQL) with 10 queries |
