quick question im working on this memphis amp but the same output keeps blowing.
#2 |
If it has parallel outputs, check the gate resistor for the one blowing and confirm that the connection between the gate leg and the gate resistor terminal reads 0 ohms.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
also could a gain pot cause distortion?
#4 |
It could have an intermittent connection (either on the wiper or on the terminals) that could cause the signal to be distorted. Where the pot is in the feedback loop it could cause the signal to become extremely distorted if it opens or has a bad connection.
Can you post a photo of the distorted signal?
#5 |
#6 |
when it plays it sounds full of static and when bass hits it cuts out and comes back in.
#7 |
Set the scope to 5v/division. Drive a sine wave into it (50-100Hz) to a level that will deflect the trace on the scope ±3 divisions. Set the timebase on the scope so that there are ~3 full cycles displayed. You don't need to have a speaker connected. Post a photo.
| quick question | timwebb | Car Audio | 15 | 30th November 2010 12:05 AM |
| Quick question | Metra90 | Car Audio | 3 | 29th May 2010 05:10 AM |
| Quick question... | WackiCO | Car Audio | 21 | 29th March 2007 08:38 PM |
| Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 04:20 PM |
| Page generated in 0.06718 seconds (80.71% PHP - 19.29% MySQL) with 11 queries |
