#41 |
What is U4?
Is it shorted?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#42 |
U4 is KIA431.
it's not shorted |
#43 |
Does R40 connect to one of the pins on the closest opto-coupler?
If so, which pin?
#44 |
yes, it is directly connected to pin #5 of U5 (TLP521-2).
#45 |
Are you sure that it's pin 5?
I'm working off of a schematic of an amp that I believe is similar and it looks like it should go to either pin 1 or pin 3.
#46 |
R40 is connected to the pin with the red dot.
#47 |
Did you follow the trace or did you find the connection with your meter?
#48 |
both. first the meter. then i followed the trace and it leads directly to R40
#49 |
I'm assuming that the circuit is like the one below but the diodes of the opto-coupler are on the low side (pins 1-4). Can you find any resemblance between this circuit and the one in your amp?
#50 |
yes, i believe they're similar.
pin #9 on SG3525 is connected to pin #8 (collector) of TLP521 and pin #7 (emitter) of TLP521 is 1k ohms from ground |
| Problems with Planet Audio Amp | unky | Car Audio | 3 | 24th March 2011 07:04 AM |
| Planet Audio ZR300.4 | o. l. t. | Car Audio | 25 | 24th May 2010 03:46 AM |
| Planet Audio VX2200D | tdetlor | Class D | 0 | 4th February 2010 01:58 AM |
| Need specs for Toshiba, Planet Audio | SharpyWarpy | Multi-Way | 0 | 21st April 2007 06:00 AM |
| Planet Audio amp | rader | Car Audio | 3 | 7th November 2006 08:50 PM |
