Go Back   Home > Forums > General Interest > Car Audio
Old 24th December 2010, 04:38 PM   #21
The amp is repairable but it would be time consuming. I'd suggest that you reassemble it and return it to its owner.
For drivers, if the through-holes are large enough, I generally use BD139s and BD140s as subs for most all driver transistors in amps that use 2S or KT prefix transistors.
Old 24th December 2010, 04:53 PM   #22
Perry,
Im Gonna try to get this amp up and running again since he said he will pay good to have it repaired . I will order new driver transistors for it .
Also since the pads for the driver borad are burnt off the board and i need to make the connections more reliable . whats the best stuff to use to to make better connection on the pins of the driver board to the main board?
I was thinking something like computer ribbon wire and stripping the coating off Or should i use something else?
Old 24th December 2010, 05:13 PM   #23
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
owner could send it to DD, he should give them a call and talk with them
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 24th December 2010, 05:26 PM   #24
I generally do something like you see in the attached photos. Scrape the solder mask away on the top of the board and lay a wire (resistor leg or similar) and pass it through a hole that's been drilled in the board near the missing pad. Then form a loop around the through-hole.
A number 60 drill bit is a good size for this.
Make sure that there is no copper on the opposite side of the board where you'll be drilling.
Don't attempt this on boards with more than 2 copper layers unless you confirm that there is no hidden copper where you're going to drill. This can sometimes be done by shining a bright light at the opposite side of the board and confirming that light is passing through the fiberglass where you want to drill.
Old 24th December 2010, 05:41 PM   #25
Thanks Perry,
Thats what i was thinking to do also.
Next question is i found 3 out of 8 rectifiers with broken legs on them.
They are FMG36S and FMG36R .
Do you know of a place to get theese from or a good replacement?
Old 24th December 2010, 05:51 PM   #26
I know of no source for the 36R. There are likely subs for the positive rectifier but you'll have to find the negative (36R) first.
Digital Designs Z1 mike49504 Car Audio 21 23rd October 2010 03:46 PM
Digital Designs Z2 teen Class D 4 6th October 2010 06:59 AM
Technics SU-Z2 refresh or modification Goetz Solid State 0 12th August 2007 08:52 PM
Digital tube designs? martinab2 Tubes / Valves 2 27th March 2005 10:30 PM
Digital preamp designs? Helix Digital Source 11 13th September 2001 12:14 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
