My butler tubedriver 475 has very bad distortion in one channel.The other channels are fine.Switching the RCAs made no differance.It is a fairly new amp. I have it fired up and ready to troubleshoot with your help.Meter on standby.......thanks Robert
#2 |
Are the tube cards removable?
try swapping them and see if the noise moves to a new channel, could be a bad tube!
All my battles have been won, But the war has just begun. |
#3 |
A bad tube does sound like a possibilty.The tube cards are souldered in,no way to change them easily.......Robert
#4 |
Have you tried moving all of the pots and switches through their entire range to see if it makes a difference in the distorted channel?
Does the channel ever play cleanly?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
There are no switches,there are only two gain control pots(one for each channel) and there is no change when turning them up and down.The distorsion is always present.........Robert
#6 |
Do you have a scope?
#7 |
diyAudio Moderator Emeritus
I found that tube's heater often dead in this amp. Look at the tubes from the top, see if there is orange points glowing. If not, then the heather is dead.
#8 |
I have a Tech 465,but I dont have many scope skills,can you tell how to hook it up and what buttons to push?All the tubes have two glowing dots on the top side.Thanks for the responces...... Robert
#9 |
What probe are you using?
Do you see a trace when the beam finder button is pressed? Set the trigger mode to auto. Does the scope produce a trace? If not, turn the intensity up a bit until you have a visible but not overly bright trace.
#10 |
Thanks perry,here is a pic. of the trace and one of the two probes.I also have BNC to RCA adapters for hooking up with RCA patch cords....Robert
| ppi tubedriver kit,issues | robertleo | Car Audio | 5 | 24th July 2008 04:38 AM |
| left channel distortion | mic_ael | Chip Amps | 6 | 17th February 2006 12:13 AM |
| distortion in one channel | randytsuch | Chip Amps | 1 | 3rd October 2003 07:25 PM |
| distortion in one channel of tube amp | fragman56 | Tubes / Valves | 6 | 27th August 2002 12:17 AM |
| channel distortion | sriegel | Pass Labs | 15 | 13th February 2002 06:23 PM |
| Page generated in 0.10509 seconds (77.16% PHP - 22.84% MySQL) with 11 queries |
