newbie needing help i got this amp months ago and i never really get to work on in sinse i was allways have other units to work on.Here is the deal local trade in jl 500/1 slash pcb rev-3 100006 .Before me posting here i spend good 2-3 hours inspecting the unit and i didnot foud and bad power supply or output fets.All resistors near the output are teasted and all with the tolerance.There is no burn marks or signs of previous repair ,when conected to the power supply them amp works but the audio output is very very low -10 watts max.i left it working for good 30 min and no overheating in the power or output side,no current on the speaker conectors.The audio output is clear with no distortion but very low.No ternal or low ohm lights any help is apresiated
#2 |
The input voltage switch near the RCA input jacks may be in the wrong position. I'm assuming that you have the gain control fully clockwise.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
input voltage sellection is set to low .week aggo i had same rev-3 jl audio for repair and i swaped the input boards but the amp keeps playing very low.The only part that i see must be changed is those large capacitors near output section 1200uf 100v-they have the bubble on the top.I ve seen plenty amps working fine with those capacitors bad.
#4 |
Is any LED on the top of the amp lit other than the power LED?
#5 |
That bubble is just the plastic blow out shield for the caps vent on the top, they just about always look bubbled, but have nothing to do with the capacitors health state.
All my battles have been won, But the war has just begun. |
#6 |
nope when i apply power to the unit power light comes right away .I spend like 30min watching the unit working and at no point there was and termal or low ohm light.No smoking or overheating parts .Audio is clear all the time no distortion but very very low.
#7 |
Post the voltages on the 10 pin connector near the power/ground terminals. Use the number scheme shown in the attached image. Copy and paste the following list into your reply.
Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10:
#8 |
Ok perry i got the voltages
Pin 1: 0.00v Pin 2: 15.1v Pin 3: 14.6v Pin 4: 7.5v Pin 5: 14.5v Pin 6: 14.5v Pin 7: 0.7v Pin 8: 14.4v Pin 9: 14.4v Pin 10: 0.00v |
#9 |
Is pin 2 positive or is it negative 15v?
#10 |
Its negative 15.1v
| Jl audio 500/1 Transistor clamps | spooney | Car Audio | 3 | 10th April 2012 03:22 PM |
| JL Audio 500/1 | mike49504 | Car Audio | 1 | 15th August 2010 09:02 PM |
| jl audio 500/1 | megael9 | Car Audio | 12 | 28th May 2010 11:01 PM |
| JL Audio 500/1 Amplifier Repair Help | Audioguy564 | Car Audio | 10 | 27th August 2009 02:24 AM |
| jl 500/1 powers up but no sound HELP | fallenskater654 | Car Audio | 1 | 4th March 2008 05:17 AM |
| Page generated in 0.12533 seconds (64.35% PHP - 35.65% MySQL) with 11 queries |
