Go Back   Home > Forums > General Interest > Car Audio
Old 9th January 2011, 09:13 PM   #21
Hey guys,
I'm working on the same amp and need to replace some resistors but I can't read the numbers of of them. Call y'all find out what the numbers on r600 through r607 are for me.
Old 9th January 2011, 09:51 PM   #22
47 ohms
Old 28th March 2011, 06:42 AM   #23
My 500/1 PCB 100006 Rev 10 has the same symptoms as the OP.. I've found relatively the same voltages at the 10 pin connector near the power/ground/remote terminals. Though I'm having trouble locating Q515 any help would be appreciated
Old 28th March 2011, 11:20 AM   #24
It's not marked on the rev.10 amp but I think it's the one indicated in the attached photo.
Old 29th March 2011, 01:41 AM   #25
Desoldered Q515, no still only getting ~.3v AC out of the speaker terminals at max gain. Do you do side jobs?
Old 29th March 2011, 02:47 AM   #26
Sometimes but shipping costs ad significantly to the cost of any repair.
What are you using for a signal source?
Did you have it installed when it failed?
Old 29th March 2011, 03:43 AM   #27
I switched out the subwoofer with a brand new one, as soon as it powered on with the new woofer is when it failed. I was using an iPod with a mini to RCA cable as a signal source to test. Shipping cost isn't a problem, if it can't be repaired I won't need it back.
Thanks,
Mark
Old 29th March 2011, 03:58 AM   #28
What is the DC voltage on each of the speaker terminals (one positive and one negative) with the black probe on the amp's main ground terminal?
Old 19th August 2011, 12:14 AM   #29
gsxtasy is offline gsxtasy  United States
I'm having almost the exact same issue with my 500/1. I just put in a new 8w7 and hooked it all up and it was pretty quiet, so I went to adjust the input sensitivity as described by the manual.
So I get it all setup, and even with the gain all the way clockwise, while running a 50hz sine tone, I am still only getting around 5.5v on the sub output terminals. This is with the input sensitivity switch on low. On high they are even lower. It's supposed to be up to 38.7v for a 3 ohm sub.
I don't know too much about this stuff, so from the sounds of it, this fix is going to be over my head. But I thought I'd ask.
I'm using an Alpine CDE-126BT headunit.
I have defeated all EQ's on the headunit, and on the amp itself. Voltmeter is on AC.
Thank you in advance.
Old 19th August 2011, 12:21 AM   #30
Do you have the input selector set to low?
If you have any other questions, start a new thread. Include the information in post #29. In the subject line, include the amp make/model and the symptoms.
Jl audio 500/1 Transistor clamps spooney Car Audio 7 6th November 2012 03:45 AM
JL Audio 500/1 mike49504 Car Audio 1 15th August 2010 09:02 PM
jl audio 500/1 megael9 Car Audio 12 28th May 2010 11:01 PM
JL Audio 500/1 Amplifier Repair Help Audioguy564 Car Audio 10 27th August 2009 02:24 AM
jl 500/1 powers up but no sound HELP fallenskater654 Car Audio 1 4th March 2008 05:17 AM
Copyright ©1999-2013 diyAudio
