Go Back   Home > Forums > General Interest > Car Audio
Old 2nd December 2010, 02:59 AM   #1
Fixer is offline Fixer  Canada
Default Can I check hexfet out of circuit Xtant Amp
If so how is it done I working on a xtant xt1001 and have no schematic on it and would love to work on it and it been worked on before and need to any help I can get. It turned on the sub is driven full out and reverse the leads and the coil is full in . I suspect outputs but never worked on a Hexfet Amp before it acts like outputs and would like to check them.
been a tech for 36 years but this is a new animal for me hexfet
Old 2nd December 2010, 03:30 AM   #2
HEXFET is a trade name. The transistor is nothing more than an N-channel, enhancement mode MOSFET.
Old 2nd December 2010, 10:25 AM   #3
When I check the fets they will turn on with DVM in diode checker mode. They should conduct(on) and non conduct (off) like a standard mosfet power fet? I see there is a zener added between sorce and drain inside them but they should check the same as the regular fets on or off with DVM in diode checker mode. The zener checks good but that is all that biases so the fets open(bad)?
Old 2nd December 2010, 11:35 AM   #4
Should read when I check regular mosfets power outputs they will turn on with DVM in diode checker mode.
Sorry about that these just check off
Old 2nd December 2010, 12:06 PM   #5
I need a pic if the section of the amp board that has the mute Led as a couple smd semiconductors are not right. If anyone can help? They were changed and the other shop was guessing what they were as the had no schematic or cross numbers to go by and have way of knowing what the originals were so a pic would be very helpful. Also the original problem was it was in mute mode axtant told him over the phone as the led was lit they tell me and they said they said they did not know how to take it out of mute mode?
Old 2nd December 2010, 06:50 PM   #6
X1001 or XT1001?
Go to the FET section of the following page:
Basic Amplifier Repair - Transistor Test Applet Link
What output transistors are they using?
Old 2nd December 2010, 08:47 PM   #7
Perry your the man thank you
they are using FB42N20D in the section I am working on
the help is very much appreciated
Albert
Old 2nd December 2010, 08:51 PM   #8
my type error X1001 not xt1001 sorry about that
Albert
Old 2nd December 2010, 09:46 PM   #9
What parts do you need a photo of?
Old 3rd December 2010, 01:20 AM   #10
the section on the input side has the amp gain adjust,Q236,D262 ,Q221,R222 and LED 236 (mute led)
thanks
Albert
HEXFET amp - please help me fix it. raise0 Solid State 69 29th April 2010 05:06 AM
HEXFET amp silverchris Solid State 9 31st October 2006 03:38 PM
HEXFET amp in Elektor Taliesin Solid State 10 21st May 2003 02:44 PM
3rd generiation HEXFET vs. 5th generation HEXFET DarkOne Solid State 3 12th April 2002 07:51 PM
Page generated in 0.10621 seconds (79.33% PHP - 20.67% MySQL) with 11 queries
