need help to build my own smps based on blaupunkt schematics gta400 please
Old 8th December 2010, 01:02 PM   #21
Perry Babin is offline Perry Babin  United States
Set the timebase to 2mS
Set the vertical amps to 0.5v/div.
Set the coupling to DC.
Set the vertical position of the trace in the center of the display.
Set the trigger mode to auto.
Set the trigger source to ch1.
Clip the probe on the calibration point.
Do you see a locked square wave?
Old 8th December 2010, 01:11 PM   #22
Ground Zero is offline Ground Zero  France
No i haven't a square wave
with your setup i have this ??
Old 8th December 2010, 01:14 PM   #23
This is a better picture with your setup
Old 8th December 2010, 01:14 PM   #24
That's a square wave. Set the time base a few clicks clockwise until you have about 3 full cycles on the display.
Adjust the focus to get as sharp a trace as possible.
Old 8th December 2010, 01:29 PM   #25
ok thanks perry
i have this is it ok ?
this is the picture:
I surrounded two buttons, when i touch them the functions are the same is it normal ? they align the trace to horizontal...
Old 8th December 2010, 01:42 PM   #26
The top one should move the trace from side to side. It's to align the trace to the markers if you're going to use the scope to make calculations.
The bottom one should make a difference in the vertical amplitude. Leave it in the 'cal' (fully clockwise) position.
Old 8th December 2010, 01:48 PM   #27
great thanks perry
i have a better picture of the scope from the owner
the website
CQ620C/620CF/640C/640CF
can you tell me please if i do a good deal for the price or ......259.5 euros
i have also a button near horizontal position call swp/var may i need to set it to cal position or not ?
for the trigger i have a button name level can you tell me if i need to set it or not ?
how can i use it to mesure a dc voltage please ?
Old 8th December 2010, 01:59 PM   #28
Only you can determine if the deal was OK.
Set the swp/var to cal.
The level control will be used to make the scope trigger properly on the waveform.
You use a voltmeter for voltage. You can get a rough reading on the scope. Go to page 73 of my car audio site. It tells you how to measure the voltage on a scope.
Old 8th December 2010, 02:02 PM   #29
cool Perry
I will go on your website
thanks
so if i understand i must set all button on "cal position" for a standard measurements ?
Old 8th December 2010, 02:07 PM   #30
If you don't have the controls set to cal, you can't use the scope to measure time, frequency or voltage.
need help to build my own smps based on blaupunkt schematics gta400 pleaseHide this!Advertise here!
car smps based on TL494 himanshuraval Car Audio 54 5th January 2013 03:45 AM
Need SMPS circuit for LM3886 based audio amp pradeeppk Power Supplies 97 24th May 2011 08:20 PM
search service manual schematics blaupunkt gta4100 or gta400 Ground Zero Car Audio 0 28th November 2010 10:26 AM
Need urgent help with SMPS SG3525 based mastero Power Supplies 22 9th August 2006 01:30 PM
Car poweramp SMPS repair TL594CN based design, help! Puggie Power Supplies 3 2nd August 2006 09:21 PM
