need help to build my own smps based on blaupunkt schematics gta400 please
Old 11th January 2011, 06:48 PM   #141
Ground Zero is offline Ground Zero  France
Hello
For the moment i have no caps
I search a good website in European union who sell condensators for a good price so if someone have this it will be cool
i search condensators of 4700F/25V with dimensions for D 18mm "max" and Length is not "really important"
thanks in advance
Old 11th January 2011, 07:26 PM   #142
luka is offline luka  Slovenia
luka's Avatar
fr.farnell.com
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 12th January 2011, 12:44 PM   #143
Hello Luka
Thanks but i know farnell, the problem is the price of shipping cost, it's expensive "12" euros for just 8 condensators
Old 12th January 2011, 03:18 PM   #144
luka's Avatar
well then find local store, it won't get any cheaper then that
I FEEL SLOVENIA
Old 12th January 2011, 05:26 PM   #145
I'll try to find a store to finish my amplifier
Old 25th January 2011, 11:25 AM   #146
Hello Guys
I finish my smps but i need to find a pretty box for it
Do you think i can use a plastic box ? or a box like that
Galaxy 40 - 10mm - HIFI2000 GX248 - 40x230x280 - Facade 10mm Noire
I think the plastic will be more simple to use but i'm worry about the heat of each components
If you have other box to advice me please ?
I need theses dimensions inside the box:
width: 31cm
depth:28cm
height: 4cm or more max 6 cm
Thanks in advance
Old 28th January 2011, 11:04 AM   #147
luka's Avatar
if you don't buy to big, and you can still put amps in, then metal is better, since you can use it as cooler and it looks great
I FEEL SLOVENIA
Old 29th January 2011, 04:34 PM   #148
Hello Luka
Ok thanks
For the moment i stop the project because i need money but i will continue it soon
Old 19th August 2011, 01:03 PM   #149
Hello
I've got news about my smps
I change the capacitors value who are in serial with the snubbers resistor.
On the original schematics it use 100nf, with the snubbers resistors who comes really hot "about 106C and seems grow up..." and the output square wave on the primary winding is not perfect.
In fact i decide to use a 10nf capacitors with 22ohms 10w resistors snubbers.
Now the square have on the primary winding is better and the (resistors/transformers) have a temperature of about 49 C after burningtest of 30 minutes.
In the next day i will build other smps
need help to build my own smps based on blaupunkt schematics gta400 pleaseHide this!Advertise here!
car smps based on TL494 himanshuraval Car Audio 54 5th January 2013 02:45 AM
Need SMPS circuit for LM3886 based audio amp pradeeppk Power Supplies 97 24th May 2011 07:20 PM
search service manual schematics blaupunkt gta4100 or gta400 Ground Zero Car Audio 0 28th November 2010 09:26 AM
Need urgent help with SMPS SG3525 based mastero Power Supplies 22 9th August 2006 12:30 PM
Car poweramp SMPS repair TL594CN based design, help! Puggie Power Supplies 3 2nd August 2006 08:21 PM
