Go Back   Home > Forums > General Interest > Car Audio
Old 29th November 2010, 04:27 AM   #1
nominds is offline nominds  India
Default where to connect audio input on the chip of XR-3324
With your help i got XR-3324 Manual (Perry helped me).
I tried to input(from a mp3 player) using 3(LFIN), 34(RFIN) and 21(GND) but audio quality was not good. then i tried with 11(LTOUT), 26(RTOUT) it worked, but the volume control option is not working. Though i change the volume it doesnt affect.
I have to adjust the volume in my mp3 player.
Can anyone please help me where to connect the left, right and ground, (audio input ) on the PCB.
I have attached Chip Diagram
If you need the Service Manual below is the link
http://chitkuls.webs.com/sony_xr-3324_[ET].pdf
Naveen
Old 29th November 2010, 04:59 AM   #2
Have you checked the output level of your MP3 player and compared that to the input level spec of the chip you have posted. most likely you dealing with a level mismatch issue where your Mp3 player output is either too high or a mismatched impedance issue..... it appears that you selected the correct input pins to begin with, so this is why I jump to the conclusion that there is a signal level issue.
Another possibility is a DC offset issue, are you capacitor coupling your connection to block any strange DC offsets that may be occurring ??? if I were you I would not be making any direct connections without the use of a DC blocking cap inline with the signal before it enters the HU circuitry....hope this helps some...
Old 29th November 2010, 05:16 AM   #3
Do you want to retain the use of the cassette player?
Old 29th November 2010, 08:41 AM   #4
I am using a samsung ypU3 portable mp3 player which has very low output.
Perry: No I dont want to use the cassette player.
Old 29th November 2010, 08:57 AM   #5
On IC501, solder a bridge between pins 1 and 2. Solder another bridge between pins 6 and 7.
Break connections to the tape head at points 9, 10 and 11 on CNP901.
Connect the RCA shield to the line that was connected to pin 10 on CNP901. Insert a 10uF cap between the RCA shield from the mp3 player and the circuit. The value is not critical but the positive terminal has to connect to the op-amp side of the circuit.
Connect the left and right signal lines to the side of C501 and C502 that were originally connected to pins 9 and 11 of CNP901.
You'll have to insert a tape to get the audio to switch to cassette.
Don't expect it to work perfectly. It will likely take a bit of tweaking to get it right.
Old 30th November 2010, 06:05 AM   #6
Oh Perry you are genius, Fantastic., It worked.,with a little tweak.
Thanks a lot
Old 30th November 2010, 08:41 AM   #7
What else did you have to do to get it working?
Old 1st December 2010, 06:02 AM   #8
Just Broke the connections from the tape head. and Directly connected the left right channels to pins 1 and 7 and the ground to 4.
Old 1st December 2010, 06:10 AM   #9
Did you jump between 1/2 and 6/7?
Did you use the cap between shield ground and circuit?
Old 1st December 2010, 06:45 AM   #10
No i didnt use the cap. Do you think i have to. Because its working without that.
Help for sony XR-3324 - I want to add Auxiliary Input nominds Car Audio 6 26th November 2010 04:29 AM
IC with SPDIF input to USB or 1394 (or with HDMI input for audio stream) VickHard Digital Source 2 26th March 2010 02:17 AM
quick connect audio loninappleton Parts 6 28th July 2009 02:51 PM
How to connect PMD-100 chip with Sony's CDX 2750Q Dsd decoder soundofvoid Digital Source 1 12th April 2007 09:15 PM
how to connect stereo DAC chip to mono application gene Digital Source 3 9th December 2001 09:32 AM
Page generated in 0.10600 seconds (76.49% PHP - 23.51% MySQL) with 11 queries
