Hi
i have a repaired kicker zx1000.1, i was pushing a kicker l7 15" when it burn, now is repaired but not have sound. the amp had the PS burned, i change the irf3205's, the 2 tip41c, one tip42c, all the SMD resistors of the irf's, i replace the drivers 2sd667 with 2sd400 and the 2sb647 with 2sa965, The amp turn on, have the green light and the relay click sound, the sink dont put hot. When i was repearing the amp, the amp had the red light, dont click sound i burned the new irfs, when i change the tip's and two diodes of the tips and the drivers, i solve the problem and amp turn on but dont have output. |
#2 |
Is the amp producing rail voltage?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Yes, the irf's has these values: (front view)
first leg: 4.44v second leg: 12.2v third leg: ground but in the tip's the values are wrong in the first tip41c i can't measure the values, only the third leg, it has -13.96v the second tip41c has 12.6v in the first leg, dont have measure in the second and 11.97v in the third leg. the tip42c has 11.7v in the first leg, 11.97v in the second and 0.12v int he third leg. i also change the c120ph diodes, near to the tip's. I am confused with the order, is tip41c-tip41c-tip42c? i dont write the order and i dont remember. other doubt, in the electronic shop, they sold me tip41a, i put these in the amp, they said me it is the same as tip41c, is correct? or here is the problem? other doubt, the u1d smd diodes near to the inductor, i need to replace? that values should be? |
#4 |
Measure the DC voltage on the TIP transistors again but this time, place the black meter probe on the negative speaker terminal.
Does the relay engage?
#5 |
The values are the same, only change the first tip41a in the third leg measure -3.86v, the relay engage and disengage when turn on and of my sistem, its ok.
But i noticed something, in this test i dont use the sink, only the circuit table and the protection/power leds. and the irfs dont heated, only the tips are little warm i think is normal, but the irfs when i touch some of irfs i receive a little discharge, and by accident i touch the two mospec f30d40d on the other side of the PS and i receive a big dischargeˇˇ i think everything is working but a nonsense thing is wrong. what else i have to check? |
#6 |
When you measured the DC voltage on leg 1 of the power supply FETs, did ALL of them have ~4.4v?
The voltage on the center legs of the first two TIP transistors should be about -24v and +24. The voltage on the center leg of the third TIP transistor should be 15v. Black probe on negative speaker terminal for all of the TIP transistor voltages.
#7 |
i check the values, in the first and second tip, the center leg i have -13 and 14v but it isn't constant, i use digital multimeter.
and in the third tip the center leg has 12v. but i noticed one thing, the 5th irf3205 has 4.4v inthe first leg and drop down to 0.01v, i think here is the problem, i check that and i notice what happen. |
#8 |
i replace one irf3205, now everyone of the irfs have 4.4-4.6v in the first leg, 12v in the center leg, and ground in the third leg. but the amp dont has output, the values of the tip's are the same like the last repply.
#9 |
Do you have an oscilloscope?
#10 |
no, i dont have one, what i should to check with that?
| Kicker zx1000.1 repair question | TonyK2003 | Car Audio | 5 | 9th January 2010 06:43 AM |
| Kicker zx750.1 | texasrebel1 | Car Audio | 2 | 10th January 2009 04:46 PM |
| I need help with a Kicker DX700 | chipper | Class D | 5 | 8th January 2009 07:45 PM |
| Kicker ZX1000.1 repair | djQUAN | Car Audio | 98 | 4th July 2008 03:40 PM |
| Kicker Vs. Memphis | irokpierce | Car Audio | 1 | 23rd August 2005 03:12 PM |
| Page generated in 0.10081 seconds (80.50% PHP - 19.50% MySQL) with 11 queries |
