#41 |
It looks like the MIC4426 and TC4426.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#42 |
thanks for the quick answerˇˇ
but, There is another circuit I can use? because here is dificult to find this circuits and i cant find one with that part number thanksˇ |
#43 |
I know of no other drivers that would be the same. You'll have to order them if you can't get them locally.
#44 |
I HAVE A KICKER ZX 1000.1 NO OUTPUT TURNS ON GREAT GOOD CLICK BUT NO OUTPUT WHAT SHOULD I LOOK AT FIRST??? PLEASE HELP
#45 |
Speakerholic
Take your caps lock off and keep it to this post and see what happens. Multiple posts not required.
Good luck. |
#46 |
i have looked at my zx 1000.1 turns on great but no output i have no scope so i cant drive power hat way is there another way???
#47 |
If no one else can help, start a new thread and I'll try to help. I won't reply in a thread for a different repair.
I don't understand the statement about powering the amp and the scope.
#48 |
hi, im back, i replace the ir4426 with tc4426, and the optos 2601 with the 6n137, i have all voltages ok, but the output fets are not working.
i put a wire betwen rca shield and amp ground, not sound. about 110volts on the outputfets, so the PS is working fine what i should to check?? |
#49 |
i see in other post how to check the out pin in the preamp, i do this:
put a 100mhz signal with a player conected to the rca inputs, turn on the amp relay engaged and checked is ok check the volts in the gnd and out pins on the preamp i have -0.47 volts on this pin, with and without signal, i know something is wrong, but i dont know who is or where start to check. |
#50 |
i check the voltage witch dc, not acˇ
now i check with ac and i have 0.01 to 0.70 volts in ac, but i change the gain pot because the other person who want to repair the amp stole me this pot, so i change with a common pot of 20k, i solder only 2 pins, the pins who change the oms from 0 to about 20k, so its ok but this pot is 20k or other value??? |
| Kicker zx1000.1 repair question | TonyK2003 | Car Audio | 5 | 9th January 2010 06:43 AM |
| Kicker zx750.1 | texasrebel1 | Car Audio | 2 | 10th January 2009 04:46 PM |
| I need help with a Kicker DX700 | chipper | Class D | 5 | 8th January 2009 07:45 PM |
| Kicker ZX1000.1 repair | djQUAN | Car Audio | 98 | 4th July 2008 03:40 PM |
| Kicker Vs. Memphis | irokpierce | Car Audio | 1 | 23rd August 2005 03:12 PM |
| Page generated in 0.08786 seconds (83.03% PHP - 16.97% MySQL) with 11 queries |
