Im in the process of bringing this amp back to life. The modle i have is the 2300x Black heatsink with gold lettering.
I have a couple questions Wondering what is a good power supply fet for this amp?? Since the fets are missing. There is a resistor thats to burnt to tell the value wondering if anyone knows the value of R429 located in front of the rectifier. And what transistor goes in Q220's spot since its missing |
#2 |
#3 |
Does the amp have both rectifiers together or does it have one on each side?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
Amp has 1 on each side.
#5 |
The photo I have isn't too very good but it appears that Q220 is an MPSA42. Since the circuit board designations are under the components, I can't tell which is R429. Look at the photos.
#6 |
The resistor thats missing in mine is the 1 closet to the cap in the row with 4 resistors. It looks like a 22.1 ohm resistor from what i can see is this correct?
Also i have another 2300 amp but the board is totally different. The one im repairing is the 2300x and the other one i have is a thunder 2300 is there a difference in output of theese amps or about the same? Last edited by mike49504; 10th November 2010 at 03:15 PM. |
#7 |
The ones closest to the caps are 22.1 ohms.
The power output is essentially the same (as far as I know) but the one with the 6 power supply FETs is probably more reliable. Most have labels on the back of them that give the power ratings.
#8 |
I also noticed this amp has the same problems as the other 2300 i have,The 1N4148 diodes by the output transistors are shorted is this a common problem when the outputs go?
Also im gonna be fixing alot of problems in the output section since i found someone tryed repairing this amp themselfs and had 540's on 1 side for the outputs and irfz48's on the other side , Gotta love it |
#9 |
Are you sure that they're 1N4148s?
#10 |
Ok maybe i was wrong . I cant make out 1 of the numbers on it .
It says 1N4150 or 1N4450 do either of thoose sound familar? |
| please help...mtx 2300 and 4320... | jaypain | Car Audio | 4 | 4th November 2010 02:52 PM |
| MTX Thunder 2300 | spooney | Car Audio | 59 | 11th August 2010 12:52 AM |
| Mtx 2300 | mike49504 | Car Audio | 39 | 20th January 2010 06:46 AM |
| Mtx Thunder 2300 | vypr | Car Audio | 35 | 21st September 2006 07:35 PM |
| Page generated in 0.10833 seconds (78.69% PHP - 21.31% MySQL) with 11 queries |
